Question about HP LaserJet 4250n Printer
Printing 2 copies
Yesterday our HP Laser Jet 4250 started to print 2 copies of everything
It did not matter from what workstation you were printing from.
Is there a setting that needs to be corrected?
Thanks
Ron
ISS RESEARCH
  • zubar Jan 20, 2009
    I have the same problem.
    I went to the pinter control panel and went to device > printing > copies and it was set to "1".
    I still get 2 copies of everything. Although when i print the configuration from the printer's control panel, i only get 1 copy printed.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Please print a configuration page and let me know if that prints 2 copies as well, If yes,
within the menu, go to configure device > printing > copies, change the copies to 1
Let me know the next update.
Posted on Oct 30, 2008
Our copier were printing fine and then all of a sudden the copies started coming out very light. It isn't a toner issue because we replaced it with a new one and even tested it with another new one....
It sounds like you need to do preventive maintenance ( cleaning of laser unit, copy optics, replace transfer and everything that is in HP PM KIT )
Call service!
Sep 09, 2011 | HP LaserJet 8000n Printer
We want to purches a laser printer for printinhg legal size paper,which printer we use
Hello
You can any of HP laser Jet with your budget for legal size printing, all printer can print legal size printing, however there are some printers for quick reference.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
Dec 10, 2010 | HP Photosmart C6180 All-In-One InkJet...
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
Printer only prints one page
Hello sir ; Before you hit print on your computer, you better set up all the informationin the printer propriety that including continuiness printing.
Oct 11, 2009 | HP Office Equipment & Supplies
My HP color laser jet 3600n printer is printing
Check your settings......there is a setting for negative in the advanced settings. See if that is the problem. Let me know
Thx
Jul 31, 2009 | Office Equipment & Supplies
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Feb 27, 2008 | HP LaserJet 2840 Printer
Hp laser jet 1010
Dr.M.subrahmanyam
1. This printer is not specifically a postript printer. It uses HP PCL printer control language, according to HP it does not support Postcript, see the table on page 15 of this pdf file: http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00442162/c00442162.pdf page
2 Screen prints are not directly sent to the printer. They are copied to the Clipboard - you must open up another application which can access graphics - WordPad , Word, Excel. E.G from wordpage paste the screen print (using Control + V or Edit-> Paste) and the contents of the clip board will appear in the document - use the print option from wordpad to print this graph to your HP 1010 printer.
Feb 21, 2008 | HP LaserJet 1010 Printer
Problem while copying
mark on scan glass, clean glass slit in where original is fed for copying
Nov 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 4250n Printer Logo
321 people viewed this question
Ben Johnson
