Question about Canon LaserClass 2060P Plain Paper Fax
To print Can I use the Canon LaserClass 2060p SuperG3 as a printer? If so, where can I get the software to download to my pc? Thank you.....
    Genius:
  • 2,120 Answers
Does this Canon printer have a chip that needs to be removed before the fax machine is discarded?
all fax/printers/copiers will have a printed circuit (PC) board which may contain hazardous materials. These are usually not accessible to users without taking the entire unit apart. In addition, there may be other sources of lead, mercury, and other hazardous materials in other parts (fusers, toners, etc.) as well. I would recommend taking this unit to a recycling center vs. throwing it in the trash. They will safely remove any hazardous parts and recycle the rest of the unit.
I found a site with many listings for recycling, many of which are free of charge.
http://www.ecyclingcentral.com/
Hope this helps.
Mar 02, 2011 | Canon LaserClass 2060P Plain Paper Fax
How to connect to computer
The unit has a parallel port interface and is supported under Windows 95/98/Me, Windows NT 4.0/2000/XP . The drivers are available here: http://www.usa.canon.com/cusa/support/office/laser_facsimile/laser_class_2050_2050p_2060_2060p/laser_class_2060p?selectedName=Specifications#DriversAndSoftware . For the supported OS versions, download the drivers and then run the exe. If it extracts drivers, note the folder in which they are stored. Then launch the Add a Printer Wizard (Printers and Faxes in XP IIRC). If your computer doesn't have a parallel port, parallel to USB adapters do exist.
Neither Vista or Win7 Compatibility Center have the unit listed. The XP driver may work in Vista 32-bit with the compatibility mode on. For Win7 or Vista 64-bit, I'd suggest a second computer, a dual boot computer or a virtual computer with an older Windows OS. For the most setups, you'll need a licensed version of the Windows OS. (Virtual computer software include: Parallels, VMWare and Virtual PC.)
With Win7 Pro or Ultimate, you can download Virtual PC and XP mode from Microsoft for free, then install them in order. The printer will install normally into the XP virtual computer. However, files from the main computer will need to go onto optical media or an external drive in order to share them with the virtual computer for printing.
I hope this helps.
Jan 14, 2011 | Canon LaserClass 2060P Plain Paper Fax
How do i set the ringer on the cannon superG3 fax machine
Press the dataregistration button,dataregistration will be displayed,press set,scroll to RX settings,select incoming ring and set it to on.Select the amount of rings you desire and press set.
Dec 03, 2009 | Canon LaserClass 2060P Plain Paper Fax
Canon laserclass 2060 fax machine showing error ##322
The fixing unit in the printer is faulty. Probably a blown element
You will need a service technician to fix this
Oct 29, 2009 | Canon LaserClass 2060P Plain Paper Fax
User guide
If you go to this web page, you can download the op manual.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
Hope that helps...
Lbcoaster
Jul 14, 2009 | Canon LaserClass 2060P Plain Paper Fax
I want to connect my canon super g3 to my inspiron
You will need a parallel cable and the correct driver.
Jun 11, 2009 | Canon LaserClass 2060P Plain Paper Fax
Hey
check where the paper comes out after a copy or fax, there is a lever ( sensor ) there, it is most likely stuck in the up position, it should be able to go down after each print. "output tray full means there is too much paper in the output bin you need to remove it before continuing to print.
Jan 24, 2008 | Canon LaserClass 2060P Plain Paper Fax
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Canon LaserClass 2060P Plain Paper Fax Logo
53 people viewed this question
old marine
old marine
