Question about SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
I have a samtron 56v 15'' monitor and using it since last four years. But, from last few days, it contain problem. Problem is that monitor does not display me red color. After some time of computer starting, sometimes red color comes back and again gone up. This things happens often(red color comes for shot time and then goes away). If you have any solution to this problem then please suggest me.. Solution would be appreciated.. Thanks in Advance...................
  • Anonymous Dec 29, 2008
    Same
Samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Posted on Mar 01, 2007
Hi all ,
what is default settings for brightness & contrast ...B'coz display makes my eyes too bad...
Bharathi
Posted on Nov 01, 2008
The C.P.U on when Sinc Out of range displays. After Restart same problem occurred. three to four times restarting then system start. continuously same problem was occurred some days. I am formatted system 3 or 4 times this month. Please solve this problem
Posted on Jun 28, 2008
Change the lm7805 ic for suppy of command section and resolt the power section
Posted on Mar 04, 2007
There shoud be dry solder on crt section that is the common problem of this monitor.only resold it and there may b no problem after soldering . my name is farid i m doing repairing of desktop monitors, and lcds from 8 years if u have another problems than connect with me my id is sameer@akela5.Yahoo.com
It happened with me as well. The welding for leads at the color tubes is sometimes removed due to any reason, viz. heating, etc. What you've to do is to ask the mechanic to weld all the leads from the color tubes properly. I hope it works for you.
Posted on Sep 14, 2006
4 Suggested Answers
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
SOURCE: Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Posted on Sep 03, 2007
SOURCE: Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
Posted on Jun 17, 2008
I have a monitor samsung and no power on it I check the fuse its ok and i found a power on power circuits what i can do
go to authorized personnel...don't try to do it by urself..
it contains more than 25000volt at EHT & power supply is most complicated circuit of monitor, so don't try it.
Aug 23, 2010 | SAMTRON 55V 15" CRT Monitor
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Need solution for the yellow display of my monitor
You can see one ic in right of crt base,plz resolder it (90%sure)
Sep 14, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
537 people viewed this question
Top Samtron Computers & Internet Experts
William Miller
William Miller
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
