Question about Daewoo DTQ-20U4SC 20" TV
DAEWOO DTQ-20V8SSFG Shows one Channel only
Unable to program the unit to accept additional channels. The TV shows one channel only. The same channel is seen on all stations from channel 7 upwards. From ch2 to ch6 I get only the raster. It goes through the programming sequence, but at the end only the same channel is seen. I have adjusted those parameters that were out of specification in the service mode adjustments. Still no change. I have tried to add the channels one by one, but no success. Every other aspects of the set appears to be working fine except the auto channeling.
Grateful your assistance.
Regards
C Riley
  • clif7455 Oct 29, 2008
    The advice received is noted, but the unit does not have a separate tuning board, so changing it probably means changing the entire circuit board. Could the loss of some voltage from the power supply contribute to this problem?
    Best Regards
    C Riley
    I will accept this solution as it offers another way to tackle the problem. I will comment on it further once the necessary checks are done.
  • Daewoo Master
  • 19,396 Answers
First ensure that you are performing the auto channelling procedure correctly.
If you are sure you have done everything in the proper way, and channel tuning still does not work, than that means that the tuning board inside your TV is faulty, and is not storing channels in memory, therefore should be replaced.
Posted on Oct 29, 2008
  • 1 more comment
  • Ginko
    Ginko Oct 29, 2008
    A defective power supply can cause the unit to shut down, and cause the tv to turn down, but it is rather unlikey that a fault in the power unit can cause problem with channels storage.
    If this is not a setting problem (ensure you are performing tuning procedure correctly), it is related to the tuner circuit, that stores channel information on an eeprom.
  • Ginko
    Ginko Oct 29, 2008
    On your TV there is no separate tuner board, the tuner is managed by an U102 circuit, however, if channels search is being performed, and channel scanned but not stored, the problem may concern the main 1701 microcomputer circuits, and the eeprom 1703, in which the main computer chip is storing information.
    The eeprom must get 5v power on power pin, or it won't store the information, also SDA and SCL pins should tested.
    The technician will need to test the power to U102 tuner, this should read 5V and 33V, otherwise that is the problem.Also check output to SAW filter on tuner circuit.
    On main CPU you need to check pins to eeprom and to the saw filter, also check the crystal connected to pins 10/11 of the CPU.
    Here is a broad diagram, if you want to do it yourself I suggest ordering the service manual from Daewoo:
  • Ginko
    Ginko Oct 29, 2008
    Here is service manual for a different model, circuits are slightly different , but structure and main components are the same.
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
How do you change contrast on Daewoo DVQ 19H1FC TV?
Use the remote to go to the tv setup menu and change the contrast there.
Dec 21, 2013 | Daewoo DTQ-19V1FC 19" TV
A black box appears and dont know how to get rid of it.
the low channel no sound indicates the tuner is failing. A black bar on top shows your electrolytic capacitors are failing and you are about to lose your vertical output transistor, then the voltage rectifier
Nov 28, 2013 | Daewoo DTQ-27U4SC 27" TV
Someone gave me a 1998 Daewoo 14N2FC TV recently (with an antenna) but so far I do not know how to set it up. All it is showing is white noise when I select setup and go through all the channels with the...
you will either need a converter box (which hooks up with a normal coax cable in the rear of the tv) or cable/satalite tv hooked up to it in order to get a signal
Aug 20, 2010 | Daewoo DTQ-14N2FC 13" TV
I have a daewoo tv modle#is dtq-2040fc chasis #100b and i am not getting any osd so i cant see what channel it on , menu and the volume level
The OSD IC microprocessor might have a problem, try first try resoldering the joints on the pins , if that doesnt work check for leaky Diodes and transistors around the OSD Microchip, if all else fails the IC has be come faulty.
Nov 04, 2009 | Daewoo DTQ-2040FC TV
How to unlock some channels that locks by mistake on your remote?
is it a cable channel that is locked or a normal TV channel ??
if its the cable channel, you can always call your cable company and have them give you the unlocked code...
if its the TV channel... what make/model is your TV ?
Feb 17, 2009 | Daewoo DTQ-13P2FC 13" TV
I have a four number passcode on my cable box
Is it a cable channel you're trying to view?
If it's a cable channel ring up the provider and ask the mfor the code.
If it's not a cable channel then I wouldn't have the slightest clue, maybe read the television guide and just check to see what
Feb 10, 2009 | Daewoo DTQ-13P2FC 13" TV
Mysterious black box?
Sounds like something is imposing Picture in picture on your scrren with no source attached to the other picture. Could be cable or Sat or some other device, or TV PIP.
Mar 19, 2008 | Daewoo DTQ-19P2FC 19" TV
Horizontal screen size
will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Mar 10, 2008 | Daewoo DTQ-25S3FC 25" TV
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Daewoo DTQ-20U4SC 20" TV Logo
588 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
