Question about Brother IntelliFax-2820 Laser Fax
Intellifax 2820? While a document is faxing to one number can I load another document to go to a different number on the intellifax 2820. I looking at buying a new fax machine to replace my Xerox Workcentre pro.
  • 318 Answers
Yes it can.But if you do manual faxing it only fax one by one.
Posted on Oct 31, 2008
Hi,, We are using the fax everyday for business. today it keep sending blank pages. we restarted it,chage toner. still the same..
Hi please check orientation of your document feeder, to see if you have loaded the original document into the document scanner up sided down. Thats the simplest solution.
Apr 04, 2011 | Brother IntelliFax-2820 Laser Fax
Intellifax 775
Lift up the document feeder (where the keypad is) and look for something blocking the paper path.
Jun 19, 2008 | Brother IntelliFax-2820 Laser Fax
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Brother fax machine Fax-2820 MFC-7225N
Hi. Open the document control panel and look in with a flashlight and see if the jam switch is stuck. also look for a small piece of paper that might be stuck in there. The jam is in where you put documents in to fax out. Lawrence
May 08, 2008 | Brother IntelliFax-2820 Laser Fax
Prints with a white line vertically down the page. How can I fix this?
Apr 25, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Mar 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
