Question about HP PSC 1410 All-In-One InkJet Printer
Problem with new ink cartridge
I recently bought refill ink cartridges for my printer and for a couple of weeks I had no problems. Then the check print cartridge light kept flashing. I took them out and replaced them again but no joy. I tried to get an estimated ink level but it only showed the black as full and didnt even show the colour. I put the old cartridges back and the printer works but the quality of printout is terrible I guess due to low ink althought the estimated ink levels show almost full on the old ones. I tried to replace the new ones again but the light still flashing. Is there a problem with my printer or is the replacement cartridges I bought suddenly developed a fault?
  • mrvicious Nov 16, 2008
    I hardly use this printer any more as I have recently purchased a colour laser, but for pictures this has far superior print quality and I'm really disappointed with this problem. On my computer, when I try to print it says "the black print cartridge is not compatible with this printer", yet it has been printing fine for months.
    I think this is just HP trying to get more money out of us...
I get the error message - the black print cartridge is not compatible with this printer - even after I replaced with a new one. My printer is an HP 1350 all-in-one. This just happened today
Doug
Posted on Apr 23, 2009
  • 39 Answers
More that likely the refilled ink cartridges are faulty and should be replaced. While some folks have pretty good luck with refilled cartridges, it is generally better to stick with the new ones.
As to the problem with old cartridges, keep in mind that the estimated ink levels are just that - estimates. However, if your printer has an option for cleaning the cartridges, try that before chunking them. Take them out, put them back in, and run the cleaning process. Sometimes the nozzles can get clogged up and running the cleaning process will clear them up. ( DO NOT TRY TO CLEAN THE CARTRIDGES MANUALLY!)
If none of this helps, you will more than likely just need to get some new cartridges. - Graye
Posted on Nov 24, 2008
Do refillable cartridges cause HP 3650 printer to not print????????
Get new ink cartridges. If they sit that long without being used the ink will dry out in the print head part of the cartridge and clog the very small holes. The clogs are inside the cartridge so wiping the outside will not clear the blockage. In the future if you have to leave the unit without it being used for over about a week you should remove the ink carts and put them in a sealed zip lock bag to prevent them from drying out.
Mar 28, 2013 | HP DeskJet 3650 InkJet Printer
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Oct 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Apr 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
Refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Aug 10, 2008 | Lexmark X2550 All-In-One Printer
Canon MP170 printer
I HAD THE SAME PROBLEM WITH THIS SAME PRINTER THE ANSWER IS THE INK OVER FLOW SPONGE IN SIDE THE PRINTER IS MOST LIKELY FULL NEED TO BE CLEANED OUT
Jul 02, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Black ink cartridge
It seems that its an hardware issue with the printer as you have already replaced the cartridge with a new one.
If the printer is in warranty contact DELL to get the printer replaced.
I would also suggest you not to use refill cartridges. Always buy genuine cartridges. As using refilling cartridges spolis the printer.
It damaged the print heads in the printer.
May 30, 2008 | Dell 922 All-In-One InkJet Printer
Losing Ink
Depending on how many times you have refilled the wells of the cartride the sensor inside may be going bad as the manufature of the cartridge only intended it for a one time use. My recommendation would be to buy a off brand compatible and refill those.
Mar 07, 2008 | Canon BJC 8200 Photo InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
604 people viewed this question
Seeker5211
Seeker5211
