Question about SanDisk Sansa e250 MP3 Player
My sansa e250 got hanged suddenly .it has happend two times.
I was playing a song on it.suddenly it got hanged.even the blue ring was not working.i let it like this and it turned off automatically.it has hanged twice.what to do??????????????
  • 8,596 Answers
Reset first b4 all else:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My Sansa e250 has hanged and only wheel light gets light is I restart the player....Plz help !!
Battery and Black screen Blue ring: Remove the back and check and see if the battery isn't fully connected
push softly but firmly on the Rubber rectangle above the battery (This is the Chip-set For the screen, and memory "Black screen Blue ring" ) and put the back on.
Jul 25, 2010 | SanDisk Sansa e250 MP3 Player
Sansa E250 hanged
I got a sansa player and it all of a sudden stopped working - It might just need to be reset - not sure if this will help but it did with mine.
If you have a power button that "slides" hold it up in the "on" position for 15 seconds.
Sep 02, 2008 | SanDisk Sansa e250 MP3 Player
Does not support few songs format
Make sure the songs are unlicensed
May 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
Every time I go to a MP3 on my "MP3 Player" it freezes
the tip about holding the power botton for like 15 seconds works but I still cant get it to play MP3 without freezing
Mar 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont turn on
try holding the power button for20 seconds or the power and play button at the same time for20 seconds.
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Sansa
Go to settings and change the equalizer settings
Jun 22, 2007 | SanDisk Sansa e250 MP3 Player
It wont read any file
If you just got this sansa, call sansa and send it back to them. you still have a warranty. they may give you some problem if you don't have the reciept bu explain that it is a gift. From what you say, you did what you should have. you can always send it to my company so we cna see what the problem is. Thanks, Connie
Jun 20, 2007 | SanDisk Sansa e250 MP3 Player
Problem with playing music
Renew your music svc sub and resync
Sep 21, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
