Question about Canon imageCLASS D320 Digital Copier
PAPER JAM MY CANON IMAGE CLASS D320 IS DISPLAYING OPEN RIGHT COVER REC. PAPER JAM..I HAVE REPLACED THE INK AND CHECKED FOR ANY JAMMING OF PAPER AND I CANT FIND ANY.
  • Anonymous Mar 19, 2014
    Canon D86o printer
  • Anonymous Mar 24, 2014
    prints off center and jams
    Scholar:
  • 62 Answers
Laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Posted on Jan 22, 2009
Rec. paper jam open right cover
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Oct 20, 2013 | Canon FAX-L400 All-In-One Laser Printer
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
Canon imageCLASS D320 Digital Copier Logo
802 people viewed this question
old marine
old marine
