I have an old misubishi 50" TV. It was working good last night. I turned on the sleep timer. Now it won't turn on. It makes a noise like it wants to tun on, but the screen doesn't show picture and there is no volume.
  • 1 more comment
  • gswenson Oct 29, 2008
    Mitsubishi big screen
    model no. VS-5005R
    AC120V
    60Hz
    270W
    Mitsubishi big screen Model No. 5005R
    AC120V
    60 Hz
    270W
    TV will not turn on.
  • 19,396 Answers
The noise like " like it wants to turn on" is an internal safety switch that tries to turn the tv back on.
What happens is that the TV main chip detects an internal fault (bad components, wrong voltage , short), and send the TV into a special diagnostic mode, where an internal switch keeps turning the set off to prevent further damage.
When this happen is said that the TV is in protect mode.
The clicking sound that you hear is the protection circuit switch that keeps turning the tv off.
Common causes for TV in protect mode are: horizontal deflection and convergence problems , power supply problems, and more.
From a user level point of you all you can do is unplugging power cord for a couple of hour, so to drain power completely.
If the problem was caused by electrostatic phoenomena, or the protection circuit was stuck because of a false bad feedback from one of the boards, this will reset and restart the tv.
If that does not work, then it means that there is a real problem, and the tV must be taken apart and tested by a qualified technician.
If you want to call a repairman you can use the phone number listed on the owner manual.
Posted on Oct 29, 2008
  • 1,879 Answers
>check the vent / exhaust fan
>what lights are ON or FLASHING ?
>re-seat the LAMP
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
Samsung 50 inch plasma switches on in the middle of the night
Check the remote button said SLEEP in not on.Like it on a timer like 30,60,120 mins,turn it all off.Ur tv might be setting on a timer setup,check ur tv menu too.
Mar 18, 2011 | Televison & Video
Samsung ps42a456p2 (42 inch plasma) won't power on, stays standby
i'm pretty sure the power supply board is dead. the most common problem with all samsungs.
Oct 30, 2009 | Televison & Video
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Tv switches off after 5 mins
There might be three or more reasons for this:
1) The sleep timer may be on causing the TV to turn off after a preset time.
2) If sleep timer is on and no signal from the remote is received for a preset time (Samsung: 15 minutes) the tv will turn itself off.
3) The TV may have been turned on automaticaly with "On Timer". If so, and no signal is received for a preset time (Samsung: 3 hours) the tv will turn itself off.
4) A fan is not working or a vent is blocked causing the TV to overheat and turn off.
For 1) thru 3), go to the "setup" menu and make sure "sleep timer" and "On Timer" are turned off.
May 09, 2009 | Televison & Video
Tv won't turn on
Although not a great solutin it does allow me to use my fairly new and expensive LCD TV. Heres what I do, UNPLUG THE TV FOR 20 -30 MINUTES, WHEN PLUGGED BACK IN YOU NEED TO VERY QUICKLY PUSH THE POWER BUTTON ON THE TV.
Let e know if this works fo you.
Mar 27, 2009 | Akai LCT3201AD 32 in. LCD Television
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Player won't turn on
Loud noise = diode is bad, and the dvd player needs to be repaired/replaced
Jun 16, 2007 | Toshiba SD-K740 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
