Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
SyncMaster 943BX screen gets dim on some applications
When I am in a Windows application, the screen is bright as normal.
When I go to a 3270 emulation application and the screen is mostly blank, it becomes very dim. If the 3270 emulation screen is mostly full of characters, then the screen is bright.
I don't understand what setting I have that is making the brightness change from screen to screen.
  • 6 Answers
SOURCE: Dark scree
I too have the same problem with the same monitor.. tv looks great OSD looks great.. pc is dim.. This has nothing to do with the inverter board or the backlight.. I believe that there is an issue with the components that render the Computer video.
Posted on Sep 08, 2008
leroyal
  • 2120 Answers
SOURCE: My Sumsung SyncMaster 170mp is
Your backlight fluorescent bulbs are weak. They are available on eBay.
Posted on Feb 01, 2009
SOURCE: SyncMaster 191t Screen is to dark
make sure you have the latest video driver.
Some video drivers you can configure/enhance your desktop settings.. ie. brightness, gamma, contrast..
If you're using windows, right click on your desktop, click Properties, choose the tab Settings, then click on the Advanced button. Choose your video card tab, and continue accordingly.
Posted on Jul 17, 2009
chanddra2009
  • 615 Answers
SOURCE: Brightness indicator windows does not go away
Dear sir This is common problem observed in many monitors compaq,HP,HCL,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor button circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.Temporarily you can warm up the monitor by hanging a bulb of 60 watt nearer your monitor to takeoff the moisture.(Dont hang the bulb too near to the monitor). It definitely solves your problem.
Have a Nice Day
Posted on Sep 18, 2009
budmrtn
  • 11361 Answers
SOURCE: My Samsung Syncmaster 943BX will not wake up.
You probably have caps failing in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 29, 2010
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Screen is very dim
Go to your applications.Then find settings and click on that to get to the menu. The click Display or Display Settings.There should then be a list and brightness should be one of the options. There will be a little slider. If you move it all the way to the right your screen will be as bright as it can go.
Feb 25, 2013 | Samsung Dart T499
When I try to use the orbicam i get a message "Camera is in use with an other aplication". The advice is to close down the other application before using the camera. But I can't find the...
- perform msconfig to disable temporary applications and services ruuning
- click start and run type msconfig
- on services tab put a check on hide all microsoft services
- uncheck camera applications and click apply
- on startup tab, disable all applications and restart the system
Jun 06, 2011 | Acer TravelMate 3270-6569 Notebook
Hi, I have an iPhone 3G 8GB and the screen seems to be too bright. Is there a Contrast application available somewhere that I can use to cancel the effects of the brightness? Thanks, J.
The iPhone has its own brightness control. You just need to adjust it to your preferred brightness. Go to Settings> Brightness
From there, you can adjust the brightness to your preference.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Aug 06, 2010 | Apple iPhone 3G Black Smartphone
How do I make the page to cover the whole screen?
Cut a larger sheet of paper. Just kidding!
What 'page'. Do you mean Windows desktop? Or an application within Windows?
If the desktop is not filling the screen, the monitor should have an 'auto' setting within its menus.
My Samsung monitor (different model) has both a menu button and an auto button.
If you are referring to an application window (you can see some of the desktop around the outside of your application, just maximise your application.
May 16, 2010 | Samsung SyncMaster 2253LW Monitor
My Samsung Syncmaster 943BX will not wake up from sleep mode sometimes. Sometimes it comes right up, other times it may be 5,10,20 minutes before the display wakes up.
Apr 29, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Dark scree
Jan 17, 2008 | Samsung SyncMaster 17" TFT LCD Monitor
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
274 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
