Question about Dryers
Squeelling I have a 4 yr old electric dryer, it just started to squeel a little. Also when you open the front door it has a slight burning smell. I don't know if this is normal , but there seems to be excess play in the drum. Thank You Shawn i have a maytag MDE6000AYW model dryer that is squeeking loudly. sounds like the same problem hope it comes apart the same way :P
    Problem Solver:
  • 4 Answers
It sounds like your belt is starting to go out. You might google the repair forums or check this site out. http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Posted on Oct 29, 2008
My indecit dryer just stopped working. Press start nothing turns, open door can hear a sound of whirring, slight burning smell
This is the forum for questions about Television sets. Try reposting in the section for washer/dryer queries.
Sep 02, 2014 | Televison & Video
Remove front panel and door on maytag electric dryer atlantis
Simple, 4 screws total. open door, remove one screw from each of the door hinge plates that are against the front panel, remove two screws directly across the door opening (other side of dryer), door can be lifted slightly and pulled out of slots, and front panel can be unhooked from retaining clips by a little wiggling at the top sides, swing it down toward the floor and lift it from bottom retaining hooks.
Apr 14, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
My dryer suddenly quit working, was working just find.
i would check the door switch behind the dryer door and the main fuse behind the back panel,you can also use a piece wire wire to jump the start switch to check that -mike
Jun 28, 2009 | KitchenAid KEYS750LQ Electric Dryer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Squeelling
your belt is bad. good news though, it is easy and cheap to replace. first, using your model number, order a new one online. there is many sites and it should cost around 15 bucks. to open your dryer, there is a panel on the bottom of the front that needs to come off first, there is usually 2 screws holding it on. then, you can get to the front panel to remove it. now, with a flashlight, look inside the bottom of the dryer to see how the belt is on (so you can get the new one on properly) and reach in and take the belt off the motor, there should be a tension pulley holding it on. then slide the drum out and out with the old and in with the new. take your time and remember how everything came apart, you should be done in about an hour.
Oct 25, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
194 people viewed this question
Top Dryers Experts
