Question about Fuji FinePix 2650 Digital Camera
Using with laptop
Alright, Whenever I load fresh batteries into the camera and plug it into my laptop, the laptop freaks out, restarting itself, going through a disk check and telling me windows has just went through a serious error. Why does it do this? The disk that came with the camera is installed onto the computer and everything I don't see why there should be a problem. It's only when I put new batteries in, otherwise it's fine.
    Genius:
  • 2,985 Answers
If you have the software installed remove it[ Start/Control Panel]Add remove software]
Let Windows do the work.
Posted on Jan 15, 2008
My 1999 Chev Silverado heater control will switch to A/C on it's own
I had this problem occur on another vehicle of mine and it freaked me out for awhile. But I found that the AC pushbutton was semi-stuck and whenever I went over a somewhat significant bump the controls would switch over to AC. I finally replaced the AC pushbutton and the problem went away. I am assuming that you have a pushbutton, right?
Oct 17, 2017 | 1999 Chevrolet Silverado 1500
Turn off itself while loading windows logo
This could be either a software or a hardware problem. the reason it works in safemode is because safemode does not initiate some on the drivers by recovery with recovery cd does. I recommend that you formatt your harddrive completely then install a fresh copy of your vista operating system. then install the correct device drivers (download from the manufactures website if you have doubts) to your system 1 by 1, restarting the system after each driver installation. this should work and if the problem persists at least you will be able to identfy which device is giving you a problem as it will restart itself again after you install the driver for that device.
Jul 15, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Hello, i have an Aiptek cam corder and the screen is cracked and now whenever i turn it on more and more blackness is creeping out of the crack and the top of the screen than before, is screen replacable...
i think you will have to buy a new camcorder because if it is creeping out like that it is probably the camera itself,well the crack has something to do with it also,but its the camera,if it was just a crack itself on the camera then you can replace it,if you didnt keep touching it after it cracked it probably would have been alright to just get a new screen,but now its messed up...
May 31, 2010 | Aiptek ISDV2.4 Flash Media Camcorder
My panasonic lumix ls80 digital camera turns itsel*** as soon as i turn it on
Be sure that your batteries are fully charged and in fact using name brand rechargeable batteries. If you are using Alkalaid, make sure they are fresh. Alks after a use that runs them down will come back after awhile for some more pictures. If you have fresh batteries and the camera turns itself off after turning it on, it probably has a problem in the power supply section or the switching section on/off on a circuit board.
May 20, 2010 | Panasonic Lumix DMC-LS80 Digital Camera
Camera wont turn on even with fresh batteries
camera wont turn on even with fresh batteries,it says:"battery low..than beep,beep and turn off"
Jan 21, 2010 | Kodak Easyshare C813 Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Random restarts, possible battery problem
stdnm11-
You should see about getting a new back cover. Try ebay, they run only a few dollars.
It sounds like you battery is coming loose a bit. Without the back cover snapped in tightly, there is a bit of room for movement for the battery. so when you snap it closed, the battery pops up of the contacts. If you know any one else that has a razor, try their cover to make sure.
Feb 05, 2009 | Motorola Mobility RAZR V3
When I turn my computer on it loads to a black screen, then stops
Your windows is corrupted the best way is to turn off when turn on
keep pressing the "F12" button insert windows disc provided with your laptop highlight cd rom dvd rom ( or something similar ) by using down arrow on keyboard press enter follow instructions to install fresh copy
PS i once had this problem
Dec 21, 2008 | Dell Inspiron 6000 Notebook
Fuji FinePix 2650 Digital Camera Logo
41 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
