Question about Keurig B50 Coffee Maker
Keurig B60 cycles through the menu incessantly!
We have had the machine for about 3 months. At first it worked fine.
Now, when you open the handle to put in a coffee pod, and you close it, the menu starts cycling through all the options, all by itself. It is impossible to make it stop. Occasionally it will stop by itself and go back to Machine Ready. The machine will then work fine and make coffee normally.
When it keeps on cycling, if you are quick enough to press the cup button while the menu blinks on Machine Ready, the machine will work fine.
I have tried unplugging the machine, but the problem does not go away.
It will go away randomly and work fine for some time (a day, a few hours, no rhyme or reason) then go back to going crazy.
It will start doing it whether the machine has just been turned on or whether it has been on for a while. There does not seem to be a pattern.
  • 1 more comment
  • beetreaux Oct 29, 2008
    I would have no idea where to find a service center to bring the machine to...
    Yes, although there do not seem to be any repair centers near here that do Keurigs. I will contact Keurig directly.
  • beetreaux Oct 30, 2008
    I contacted Keurig directly and they are replacing the machine at no charge. They are only asking that I return a part of the old machine to disable it, and then I can throw the old machine away.
    I was extremely impressed by their customer service.
  • 13,433 Answers
If you want to find a repair service, theres a finder on the right of this page ---->>>
since you have had the machine for only 3 months I beleave its still covered by warranty and you should contact your dealer instead of taking it to 3rd party repair service
Posted on Oct 29, 2008
  • 47 Answers
Happy to help u. its the problem with ur circuit board. u can go to the service center of and get it replaced. pleasure helping u .
  • pushpdeep singh
    pushpdeep singh Oct 29, 2008
    sir if u tell the me ur location and the make and model of ur product i will be happy to assist u . pleasure helping u .
  • pushpdeep singh
    i can guide u to the nearest service centre.
  • Keurig Master
  • 19,396 Answers
It sounds like a problem with the machine control assembly, in that case the part should be replaced.
  • 2 more comments
  • Ginko
    Ginko Oct 29, 2008
    If the machine does not cycle regularly, and shows erratical behaviour, like described, this can be due to a problem with the electronic small board that controls the cycle, and that should be replaced.
    If the machine had for example a clogged hose, and that the machine is just starting in this weird way, because it is taking its time in genating enough pressure to go through the hose and brew.
    In rare occasion also water inside the machine can cause a short between wirings and cause this kind of erratical behaviour.
  • Ginko
    Ginko Oct 29, 2008
    There is a phone number listed on the user manual, if you ring it you will get in touch with customer support.
    Here is Brewer Maintenance & Cleaning, perform the whole procedure before contacting support, just in case.
    Here is the phone number in US: 1-866-901-BREW (2739) , if you contact them, they may even offer you a replacement, being the machine only three months.
    If you do not want to call them you can use the online contact.
    Alternatively give us your location, and we can give you a contact.
  • Ginko
    Ginko Oct 29, 2008
    You should rate the most useful comments, you stated that there is no service centre, then accepted the solution from the expert that suggested calling a service centre, is this a system malfunction or your final decision?
    Thanks
  • Ginko
    Ginko Oct 30, 2008
    That is exactly what I told you. By accepting his solution you are rewarding instead the guy that suggested to go to a local repair centre.
    Please read the thread here and accept the appropriate solution. :
    http://www.fixya.com/support/t1184008-ke...
    We experts work as separate entities, and is rewarded only the expert that get the solution accepted, the one that get the blue flags.
    Please let me know if you are not able to chose the solution of your choice.
    Many thanks.
Can you pls tell me the service center of keurig b60 coffee maker here in the phil
Did you try : Keurig Customer Service at 1-866-901-BREW
That is all I can find for any help, maybe they can direct you to somewhere in your area. ..Good Luck
Keurig Repair Center
Jan 08, 2014 | Keurig B60 Coffee Maker
Display on keurig B60 not working will not brew coffee and how to replace
Make a positive conncetion when putting handle in the down position.
Mar 23, 2013 | Keurig B60 Coffee Maker
My keurig keeps going to the settings menu and will not brew
Handle not engaged properly. Reset and start over.
Jan 10, 2012 | Keurig B60 Coffee Maker
Keurig B60 will not turn on anymore. Was working for months with no problems.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Aug 29, 2011 | Keurig B60 Coffee Maker
I've had the Keurig B60 about 6 months. It has worked fine until yesterday, when the power went out and will not turn back on. I checked the breaker and switched outlets, to no avail. The power just...
heatman101
Jun 25, 2011 | Keurig B60 Coffee Maker
My Keurig B60 will not brew. The "ready to brew"
Having same problem with B60 turns off after 1 minute and little circle won't go away.After unit was stored for 5 months, So this is what I did. 1. I took it over to the sink and turned it upside down and shook it. 2. I dried out the whole where the water sucks up and blew through there with a straw. 3. then I sucked water out the rubber tube up top for the over flow. Then I put vinegar in the intake whole and put vinegar in the tank and let it sit overnight. When I got up in the morning i turned it on and after 1 min it shut off again so I restarted it and after a couple minuets it started to heat and my display came back and circle disappeared. Problem solved. Not sure which one worked but it is now working fine and I am now descaling it.
Feb 25, 2011 | Keurig B60 Coffee Maker
My keurig worked fine this morning. Now it's blinking "Not Ready" - none of the buttons work, unplugging it didn't make a difference, the menu button doesn't work either. Any ideas?
Sorry to read about your problem, I hope this helps you out.
if you are new with Keurig, move the handle up and down, if the unit has been used alot..
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Keurig B60 Coffee Maker
I have a Keurig B60 coffeemaker. When making a
Descale yes you should every 3 months. Use 48 oz. of white destilled vinager and follow the instructions in your use and care guide
Mar 14, 2010 | Keurig B60 Coffee Maker
Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Oct 25, 2008 | Keurig B60 Coffee Maker
Keurig B50 Coffee Maker Logo
701 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
