Question about Music
Plug from V-Amp 2, 4 pins
Hello Robotek.
I have a question for you on this subject http://www.fixya.com/support/t624729-replace_4_pin_plug_behringer_v_amp2_psu
, if I could also spread thisdivision into which pins enter the tension. My e-mail adriangogacz@gmail.com.
Adriannek
  • Anonymous Jan 17, 2009
    hello i am having the same problem locating pinout for this power supply. Any help would be greatly appreciated. Thank You.
  • Dare Nov 20, 2016
    Please, I need the v-amp2 power supply pinout too. My email :dreadex4real@gmail.com. thanks
  • 1,512 Answers
Hi Adrian
Just emailed you a pinout diagram for the vamp power supply. Hope that was what you were looking for. Cheers
regards
robotek
Posted on Nov 01, 2008
Robotek, I need this diagram too, can I have please?
Thanks!
Posted on Feb 11, 2010
My Behringer PMP1280S INPUT Chanel 1 is no longer working, after pulling out the XLR plug whilst the amp was still turned on. Any thoughts on how to fix this please?
Please see my previous answer on this subject. It's best not to repost multiple times. The questions don't post immediatly so it may take a while for them to show up on the site.
Dec 01, 2015 | Behringer Music
I have a behringer eurolive b212d no power no lights on when I push the button I hear a clike in the speaker but no power. tested the fuse its ok. could there be a fuse inside the power unit .any help...
Eurolive Active speakers from Behringer suffers of bad power supply/Amp design, if you open up the back of your speaker you will probably find that the AC connector has a burnt or loose connection as well as a black spot, if not, check the power supply/power amp coils for cracked connections, let me know for improve help.
Sep 20, 2013 | Behringer B212D Powered Speaker (550...
HOW TO WIRE GEMINI GRAPHIC EQ 3000 TO behringer djx750 proffessional MIXER
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Apr 26, 2012 | Behringer Pro Mixer Djx750 Professional 5...
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here: http://el34world.com/charts/Schematics/files/peavey/peavey_mark_3_bass_with_pa.pdf
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
Can't get no output sound from my Behringer PMX660M mixer. All lights are on, power on is on, line-ins work correctly; speakon cables good but sound when instrument played through mixer.
The power amps may be blown... PLEASE read my tip on Fixya about the hazard with PMP mixers if you use Speakon to 1/4 inch cables. The sleeve or barrel of the Channel A plug is the hot, not the tip. Touch it to ground and goodbye Channel A of the amp.
Do this test: Plug a set of earphones into the Main out L and R jacks and see if audio comes out there. (it will only be in one side of the headphone and not too strong... If both L and R have signal there is a problem with the power amp or its configuration. Make sure the slide switch is up in the MAIN L/R position (top position) If all that is correct, the power amps have probably blown. Repair takes a lot of work and getting parts from Behringer now is really hard. The amp module is an HCA2400 and the only source seems to be FullCompass.com...
Mar 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
One of the pins on the power input to the mixer is broken, can I get a replacement for this, or can I buy a replacement power supply. Thanks, Yours Sincerely, Brian Mulcahy
Yes.. if you have some basic skills you could do this yourself.
This is a very basic standardized part and even if epoxied in place can be removed with care.
The part is about 2 - 4 bucks..
You need a
1 IEC Power Jack Chassis Mount with a 10A fuse holder part number 090 443
Go to www.parts-express.com
It should be a simple repair. Make sure you use the proper fuse.. installing a lesser fuse amp wise will be fine.
Nice mixer!
Feb 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
How to connect mixer to a crown power base 2 amp and speakers
just use the main left and right outputs of the behringer to run xlr (3 prong balanced) to 1/4 inch (looks like a big headphone plug) cables into the inputs of the crown amp. the mixer has the xlr outputs and the amp has 1/4 inch inputrs, sop the cables will have to reflect that on both ends. run the outputs of the amp (rca outputs, i believe, you may have to get a rca plug to 1/4 inch jack adapter, and then use a 1/4 inch speaker cable) to the inputs of the speakers, again, the amp has rca outputs and the speakers will likely have 1/4 inputs, so you will have to address that wil an adapter. have each speaker in its own channel.
Nov 22, 2010 | Behringer *new* Behringer X1222 16-input...
Need Behringer Eurorack mixer power supply connector
Those were used for mic connectors at one time,,, they are related to the Amp 91-MC3F family of connectors and those are out of production and they are demanding $20 to $50 for one connector.
That is a ridiculous price and I would be tempted to swap out the connector for a more available design.
On eBay item 250401122616 is one but they want $13 pus $11 shipping which is a rip off.
These were used on some OLD CD radio mics.
Dec 15, 2009 | Behringer Music
Music Logo
456 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
