Question about Sony Playstation 3 (PS3) Console
Ps3 when you turn on it goes straight to message saying the correct hard disk was not found
    Novelist:
  • 111 Answers
Unfortunately for you this problem indicates that your hard-drive has become corrupt. rendering it unuseable..
You will not be able to format it using a PC due to the file system being completely damaged beyond repair. the only ways of alleviating this problem are either contacting sony customer support to fix the problem, or Purchasing your own 2.5" SATA hard drive and attempting to replace the hard drives (quite an easy task) the choice is yours.
Hope this helps.
Thanks
Posted on Oct 29, 2008
Ps3 slimline says cannot start the correct hard disk was not found
Dear Friend,
Have you consider to replace your hard drive?. That might be a good possibility why your PS3 can not start the way it should. Try that and see what happens.
Good Luck!
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Ps3 cannot start. the correct hard disk was not found
Hi if you replaced your hdd or if the old went foul try this plug your controller in with the usb lead insert a game disk, put it on standby (red Light) press and hold the power pad you will hear beep,beep, then it will shut down, Do it again beep, beep then beep beep take your finger off then follow your instincts on what it says. Also you may have to replace your hard drive ,not very expensive good luck
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Turn on. Message: ''Cannot start. The correct
you try reformatting hard drive or restoring ps3 ? do a search for this warning u will loose and saved data on console. photos musics etc...
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Iturn on it says cannot start the correct Hard disk was not found
Open up your ps3 on the right site with a small flat screw driver.
Turn out the blue screw with a small cross screw driver, slide the hard drive to the left and pull it to warts of you, note it is a 2'5 inch sata notebook harddrive.
Hook it up to a pc or mac to run a diagnostic check on it to see if it is crashed, by the way you're able to tell by the sound it makes if it crashed.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
As with many of us current and former PS3 owners you need to have your HDD (hard disc drive) replaces. sorry
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 problems again
Have you tried pulling out the hard drive and then turn it on to see what it does? If it says the same thing the hard drive may have died if not put the drive in making sure its firmly seated and power back up, make sure the power is off before you do anything. Was the system dropped at all?
Dec 11, 2008 | Sony Playstation 3 (PS3) Console
Playstation hard disk not reading
i had the same problem with fallout 3 and then i updated my system with 2.52 and then the blue ray lense quit reading so now i can't load any Ps3 games.
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Hard disk not found?!
i thik u have to format the hard disk and try it again. or may be u have change to the security settings.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
