Question about Denon AVR-1603 Receiver
Shutdown protection? HELP please
My Denon avr1603 worked perfectly for 17 months then last week it started to shut itself down (auto protect ?), read manual and disconnect all speakers, wait till unit is cooled down turn back on, after 6 minutes exactly it shuts down again,led starts flashing fast, use remote to turn back on because it is in standby mode,after 30 secs shuts down again. Take unit to sales to be fixed comes back after 3 days stating the flat cable connector to front panel was the problem, take unit home set it up after 10mins use shuts down again with the same problem all over, can anyone help me please Laurie
  • 4 more comments
  • Anonymous Mar 27, 2008
    I have the same issue. Who has resolved it??
  • fknsimple Mar 27, 2008
    I have the same issue, has anyone gotten a resolution?
  • Anonymous May 31, 2008
    My avr-1603 same problem.
    My DENON AVR-1603 found that same problem.
  • Anonymous Sep 08, 2008
    mine also having the same problem.
  • Anonymous Dec 26, 2008
    hooked up a videoke microphone and started to shut off after 30 mins. the next day i used it for movies in ps3 and was ok. can anyone tell me what the problem is?
    President:
  • 624 Answers
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
SOURCE:
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
When I turn up the volume to 12 my denon avr1603 shuts off????
Is that a 12 on a -80 to + whatever scale? I don't blame it.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 07, 2011 | Audio Players & Recorders
THE UNIT WILL KEEP SHUTTING DOWN AFTER IT IS GOING FOR A WHILE. NOT JUST THE AUDIO ALL POWER IS LOST.
Typically this is because of heat generation. There are protection circuits that will shutdown the receiver when it gets too hot. There are many reasons for this. Can you update this with the make and model please? That will help to determine the possible causes of the heat shutdown.
Thanks,
Dan
Dec 04, 2009 | Denon AVR688
I had my denon setup and working and about 6
It's going into protection. Check your speaker wires at the receiver, make sure none of the braids from the + to - are touching. Then if you still have the problem, disconnect the wires at the speakers and test power. If your receiver still shuts down, disconnect the speaker wires at the receiver and test. If the problem persists, it is a problem in your receiver and it needs serviced. Hope this helps. If you need further help, post a comment and I will help you further.
Nov 19, 2009 | Audio Players & Recorders
I have a Denon receiver, had it for a couple years now and has worked perfectly. Last week I was watching a movie and all of a sudden my receiver shut off and it blinked a red ring of death. I let it rest...
Did you recently move any speakers around or any items near the speaker wire connections?
It sounds like you may have a speaker wire shorting which is causing the receiver to go into "auto protect" mode. Check all of the speaker wire connections on the back of the receiver and at all of the speakers to make sure the wires are not touching or close enough to possibly touch.
Jul 22, 2009 | Audio Players & Recorders
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Kenwood XD-A5 - "protection" shut off feature
This is a safety feature and can not be shut off. The system is detecting a problem in the last output stage of the amplifier and is shutting down to prevent further damage. I suspect a bad coupling capacitor in the pre-amp stage. This is a relatively simple repair for an experienced servicer. Figure on $10 or so for parts plus the local labor rate.
Dan
May 22, 2008 | Audio Players & Recorders
My denon avr-a10se stop working. When I start, aftr thr quick intiation the amp shuts itself and the red power light start to blinvk quickly - please help
This unit is in protect mode. This means that a problem was detected in the last stage of the amplifier section and the unit shuts down to prevent further damage. The most common failure parts are the output transistors. These usually run between $5-$15 each. Add in the local labor rate for the total repair cost.
Dan
May 20, 2008 | Denon Audio Players & Recorders
My Head Unit stop working/shut down unintentionally
Mine is doing exactly the same thing! I suspect its a protection mode- the unit is overheating. I'm not sure what to do, there is no mention in the manual.
Dec 25, 2006 | Panasonic CQ-VD6503U Car DVD Player
Denon AVR-1603 Receiver Logo
1,238 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
