Question about JVC TH-M55 System
Powered subwoofer----sp-pwm55 Hello, I need the back part to the powered subwoofer(sp-pwm55. About three or four years ago it stopped working(after about 6 months of use). I took it apart and tried to fix it. I didn't accomplish that. So I storred it for about three years since I moved in with my girlfriend. Now I live by myself again and want to set it up(IT'S ALL LIKE BRAND NEW). But I must have thrown the powered subwoofer and the back of it away. I just ordered a new subwoofer but it didn't come with the back parts to it.(the connection part and power supply. Do you know where I can locate this item. system......TH-M55 powered subwoofer.................SP-PWM55 the serial # to the original subwoofer is.....178Y0886 Without the guts to my subwoofer it's all useless. And it's all like brand new. Thank you, Mark
bluenadas
  • 203 Answers
SOURCE: JVC TH-M505 powers off right away
The unit is going in to shutdown. My guess is a failed output. Service is going to be required.
Posted on Jun 15, 2007
bluenadas
  • 203 Answers
SOURCE: subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
petraman7
  • 1175 Answers
SOURCE: SP-PWM505
MOst of the time it is the jack that the cable plugs into that has the problem. .
Also the jack is not broken but HAS broken the solder connection TO the jack.
If you know someone who can safely take it apart and solder, let them try.
Posted on Feb 28, 2008
SOURCE: jvc th m603 center unit - powered subwoofer
Yes go to JVC.com It will cost you $20.00
Posted on Mar 31, 2008
  • 13 Answers
SOURCE: connecting an Ipod to JVC TH-M45 System
you can hook up ipod 2 different ways. the one i will use will be with a 3.5 to 3.5 mini plug connection(on both sides of cable it has i.e. head phone jack connection) and then set unit to aux in and that will give you sound from ipod. another way is with red and white audio cables to 3.5 mini plug connection. connect red and white to audio in on back of unit,and then set unit to that source.
Posted on Apr 22, 2009
Where do i find a connector cord for my powered subwoofer model no. sp-pwm606
There are a few on eBay. Search for "JVC THM505 cable" and check the 'include description box'.
If you need the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-M505J-Home-Theater-Systems-manual/id/318dj491/t/2/
Mar 16, 2011 | JVC SP-PW100 Subwoofer
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
JVC sp-pwm606
Hello, it,s very possible that it,s circuit protector built in to the sub (if it,s a self powered sub) gets to the point of overload and shuts off as a protection so that the speaker won,t get damaged and also so the internal amp tha,t pushing the speaker sound is also protected since theese amps all have heat buildup, their are two types of subwoofers ,They are the powered ones and the ones that are powered bt the surround amp ,The ones powered by the stereo surround amp/tuner tend to throw out less power to the sub and the ones that have internal power are mostly higher powered , Another thing you might want to check is your polarity to the speakers and also the omage , Most home theater system speakers are 8 ohm,s but their are speakers and amps that can be changed to 6 ohm,s ..so you might want to check the speaker rating also . Well hopefully you can use theese different methods to at least troubleshoot and discount the thing,s that are not the issues , Good luck and hope theese sugestions might help you , Sincerely Glenn
Mar 01, 2009 | JVC TH-M505 System
Panasonic Super Drive video recorder
there are three creases in the head , have you made sure those are cleard?
Oct 21, 2008 | Zenith VCS442 VHS VCR
Looking to purchase powered subwoofer
You can order the Subwoofer of the JVC website.
www.jvcservice.com
It have all subwoofer.
May 01, 2008 | JVC UXG70 Micro Audio System Shelf System
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Dec 24, 2007 | Pioneer VSX-D409
JVC TH-M55 System Logo
117 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
