Question about Dryers
Maytag dryer My dryer just stopped I cleaned it and tried to get it to restart. I set the timer and all I hear is the timer tick dryer wont come on.
  • 1 more comment
  • patriciar88 Oct 29, 2008
    Thanks how do I get to the fuse
  • patriciar88 Oct 30, 2008
    My model number is a Maytag PYE2300AY . Thanks
  • patriciar88 Oct 31, 2008
    THANK YOU GURU
    Genius:
  • 1,122 Answers
You need to check the door switch and the main fuse inside the dryer on the blower box,let me know what you find-mike
Posted on Oct 29, 2008
  • MIKE major Oct 29, 2008
    what is the model number(inside dryer door)i will fix it for you so you can change your helpful reply to a fixya reply so i can get my expert rating back-mike
  • MIKE major Oct 31, 2008
    you need to remove the top and front,use a putty knife in the front seam,one clip om each side,then remove the two front panel screwes,remove door switch wires,look for the smallest fuse either on the blower box or the heater box,let me know how you do-mike
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love you.you will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
What does it mean when a dryer starts to tick like a clock
the ticking sound you hear is the timer motor.this is normal on timed dry.on auto dry you should only hear it when the heater is turned off.if the dryer shuts off and will not start after 20 to30 min. the motor has over heated and stopped to prevent over heating.venting is the no.1 cause of this.the vent system needs to be checked first.if it is a magic chef,admiral,or maytag under a few years the part below the lint screen needs to have all that lint removed every 6mo.
Maytag dryer Model MDE3000AYA intermittently won't start. Interior light does illuminate when door is open. Normally when the timer knob is set a soft audible ticking sound is heard. When the dryer...
could have a bad timer,when it stalls try tapping on the timer or wiggling the knob to see if it will start,there's a little motor on the timer that you hear ticking and it could fail.
Jul 10, 2017 | Maytag Dryers
Dryer stopped spinning,timer still ticking,cannot get to restart.
Can you still hear the motor turning? If the motor is running but the drum is not then it is probably a broken belt or there may be something blocking the drum from spinning. The first thing to check is if the drum will turn by hand. If so, the next thing to check is if the belt has broken or slipped off. Although it is a bit cumbersome to replace, it is easy to diagnose. Unscrew the screws holding the back of the dryer on and pull the cover off. Look at the pulleys on the motor and see if the belt is intact. If those solutions don't do the trick, let me know and I will try to give you other options.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Maytag electric dryer won't start
Hi!!! You have a bad thermal fuse.easy to replace just lift up open the top cover of the dryer and the thermal fuze is in the back next to the heating element.Its round and black with 2 wire going into it its around half and inch thick next to the heating element ..Good luck..
Jan 03, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
102 people viewed this question
Top Dryers Experts
