Question about VeriFone Omni 3700
Omni 3750 contrast going out
I set the contrast all the way up and the screen looks fine but after a short while the contrast begins to get darker again. Any solution to this?
I have an Omni 3750 that I bought from a provider. I have since switched providers and now my Omni 3750 reads "download needed no *go variable". My previous provider gave me several passwords...
Here's Some that you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jan 19, 2011 | VeriFone Omni 3700
Omni 3750 is only partially printing the recipts.
You either have bad paper or you printer head is going out. Firs, replace the paper. Thermal paper goes bad over time.
Jul 19, 2010 | VeriFone Omni 3700
Add Credit to Gift cards with Verifone Omni 3750?
Get in touch with a gift card company or you processor (as many have programs) they will set you up with a program and cards and put the program in the machine.
Mar 10, 2009 | VeriFone Omni 3700
Verifone Omni 3750, set up problem
Your processor should be able to essentially blow out the memory on the terminal. From their a dummy program can be loaded to finish wiping out any residual memory. Lastly, you will need to do a completely new core load with your actual file build. The process takes much longer than normal due to the multiple core loads but it is effective. If your processor is not familiar with this or is unable, I would be more than happy to take over your services but am unable to solicit on this site. So, feel free to email me with any questions you may have at CJepson@federal-financial.com. Hope this helps.
May 27, 2008 | VeriFone Omni 3700
Verifone omni 3750
Use this Master Password from the manufacture #23378463
May 02, 2008 | VeriFone Omni 3700
I have a verifone OMNI 3750 -- reuse
You have to load a new application into it that will send anything you send to the serial port over to the printer.
Jan 23, 2008 | VeriFone Omni 3700
Retail Supplies Logo
226 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
