Question about Konica Minolta DiMAGE G600 Digital Camera
No power !
Have a prob with my camera,went to use it and seemed to have no power,i thought the battery maybe flat so i charged the battery then put it in and still no power.I put battery back onto charger to see if the abttery had charged and the battery had gone completely flat again within a couple of secs...i thought it must be the battery,i bought a new battery ,put it in and i still have no power to the camera. When you slide the lens piece across to turn it on the lens it does not protrude,just nothing! i don't recall camera being misused or being wet. Is there a way of eliminating what`the problem could be? any ideas will be appreciated....thanks
  • Anonymous Feb 09, 2008
    i have the same problem
  • Anonymous Feb 21, 2008
    I have the identical problem with my dimage G600. Any ideas on how to effect a fix to this problem....... The camera powers up while attached to the PC USB Port , Any ideas on a fix for this?
    Thanks for your help
    M
As indicated in solution #2 dirt deposits in the channel that prevents the cover from moving the switch to turn on the camera. To get at the channel to clean out the **** remove the 6 small screws (two on each side and two shorter screws on the bottom of the outside of the camera). Remove only the six screws that are holding the front of the camera body on. The silver band seperates the front of the body from the rear. Wiggle off the front of the camera body. With the lense cover closed you can wiggle off the plastic inside of the front cover from the exterior of the body. By doing this you'll expose the track that the lense cover rides in. Notice that the top track moves back to contact a black plastic switch. **** will typically be in the channel preventing the lid from contacting the black switch. Clean it all out and reassemble. Camera should work fine.
Posted on Nov 02, 2008
  • m_j_meeuwsen
    m_j_meeuwsen May 18, 2012
    Thanks a lot. I did it with my old Dimage G600 and it works. However, keep in mind to open the battery lid first before removing the front cover, cos else two small hooks will brake off that help closing the battery lid. Unfortunately, this happened to me when wiggling off the front cover. now, I removed the small spring that pushes out the battery and I seal the battery lid with some strong tape. It works. I love this camera.
Yes the usual cause of this problem is that dust/dir deposits in the channel that slide the cover and it is blocking from closing the switch....... the solution is simple....... remove the fromt cover turn it upside down so that your are looking at the cover from the back...... take a ver fine jewellers sflatheas screwdriver and gently prise out the inner front....for the front face plate... it will pop out...... look very closely at the channel the mecananism slides along,,, your will finf that dust/ dirt is prevening the it from opening fully........ clean out the dust.. that will cure the problem.. hope this helps
Posted on Jul 12, 2008
My wifes had the same problem, and just tonight I took it apart. I found that the shutter cover, was not making contact with the on switch. when I put it back together, I made sure the top right hand corner of the face, was pressed tight to the camera body. problem solved. Hope this helps and isn't to late in reaching you. Rob 5-18-2007
Posted on May 18, 2007
SOURCE:
Will not charge when plugged in
have you tried an external battery charger and a different battery?..... maybe its the camera not sending power to the battery..... or the battery is good and the camera is dead, the external charger will help you decide where the fault is.
Mar 09, 2014 | Nikon COOLPIX Cameras
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
I tried to put my pictures onto my computer last night but the computer froze so I gave up but I took pictures this morning, and it was fine. Then the next picture I went to take nothing showed up on the...
Your coin battery that powers the memory system of your camera may be failing. This battery keeps your settings and powers your on board computer. Do not confuse this with your picture battery, as that only powers the lens and picture taking ability. The coin battery holds the program. See page 38 of your manual "Replacing the Date/Time battery."
Dec 20, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Camera was working fine, but suddenly would not turn on. Thought perhaps the battery needed charging, but when camera is put on charger, the camera will not charge. The charger light flashes green when...
Well, U prob. got it wet, whatever ur name is. And it prob doesnt work. I just lost my USB cable for it. And i cant download it. But, anyway, u prob broke it. Srry charlie. Hehehe, what if ur name was really charlie. That would be funny.
Jul 26, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Battery keeps dying
Most likely the charging circuitry has failed. When you fully charge the new battery what does the battery meter read on the camera? Your two options no matter what the case are repair vs. replacement. If you need further assistance let me know.
Thanks,
Lee
May 13, 2009 | Casio Exilim EX-S500 Digital Camera
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Konica Minolta DiMAGE G600 Digital Camera Logo
139 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
