Question about Euro-Pro Steam Generator EP8001 Iron
Kenwood Steam Iron Model No KBS-11B - Cracked water tank
Could any tell me where I would be able to buy/order a replacement water tank for my steam iron. I have been told Kenwood do not sell parts? Is this true?
  • bubudoo Mar 20, 2009
    I to have this iron (Kenwood KBS-11B) and my water tank has also cracked. Can anyone out there help???PLEASE
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
  • 14 Answers
SOURCE: Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
Posted on May 20, 2009
  • 90 Answers
SOURCE: Steam escaping from water tank with EP8001 iron
your thermostats should be changed
Posted on May 30, 2009
  • 43 Answers
SOURCE: I have bought a steam generator iron it has no
go back to the purchaser and they will organise or download a manual
Posted on Sep 18, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 | Irons
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
Ssteams constantly without pressing steam trigger
Sounds like your trigger valve in the iron portion (not the tank) is jammed open. It could be from mineral deposits so maybe try running it with a solution of distilled water and a couple of tablespoons of vinegar in the tank. Wiggle the steam trigger to try to release any scaling that maybe present inside the valve. If your steaming from the iron stops, you've fixed the problem so let the iron cool and rinse the tank using ONLY DISTILLED WATER which anyone knows is the only type of water to be used in ALL appliances. Minerals in regular tap water kill appliances quickly. Never use tap or bottled drinking water even if the directions say it's okay. Iron some old rags or towels with a tank of distilled water to make sure no mineral deposits or staining steam comes out after cleaning.
If this fix doesn't work, you can buy a replacement iron portion online..try It's cheaper than buying a whole new iron but you may need a repairman...I've never tried to fix this portion of my DG5030 iron.
Aug 28, 2013 | Rowenta DG5030 Iron
Water leaking out of iron no steam I have a Hamilton Beach Steam Storm Model 14560 Lost manuel
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
Jun 20, 2011 | Hamilton Beach Steam Storm 14560 Iron
My kenwood kbs 11b is not producing steam and stand by light is flashing, what should i do?
the steam holes is plug.
If you have hard water doposit in the line try some cr7
Oct 30, 2010 | Euro-Pro Steam Generator EP8001 Iron
The iron will not produce steam.
There are several thermal sensors around the tank, did you make sure they were not damaged or bent...they are "bi-metallic" strips, meaning they are two disimilar pieces designed to have different thermal expansion rates so at certain temp they separate (open) or move together (close) telling the control logic board to enable heater. Do make sure you did not bend them or over torque them when reattaching to their respective attachment points.
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is:
or tech service:
Apr 06, 2010 | Rowenta DG-980 Iron
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Euro-Pro Steam Generator EP8001 Iron Logo
1,265 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
