Question about HP Tablets & eReaders
Image Backup problem
I have an HP a1630n. I'm trying to use a hard drive caddy with win pe and Symantec Ghost 11.0 to perform an image backup. I've succeeded backing up my other 11 computers with this same setup. This computer gives the following error message -
Question 1854-
A source volume could not be locked as it is in use by another process. Do you wish to force a dismount on the volume?
If you answer yes or not it gives you a 640 error message. I'm very computer literate and am assisted by a friend that does this same thing for IBM and neither of us can find a solution. Any ideas?
Vista volume containing system restore points
When a Vista volume containing system restore points is mounted in a Windows
XP/2003 volume, the restore points are deleted. The following error is displayed:
Question 1854: A source volume could not be locked as it is in use by another
process. Do you wish to attempt to force a dismount on the volume?
Run the task on Vista WinPE or in DOS as a work-around for this error.
Posted on Nov 05, 2009
How do I delete photos in the gallery on Samsung Galaxy tab 4?
To delete a single image, summon the image on the screen and touch the Trash icon that appears in the upper-right corner. Choose the Confirm Delete command. The image is gone.
Deleting a video isn't as easy as removing an image: You have to long-press the video thumbnail in an album. The long-press activates multiple-selection mode. For removing a video, however, just touch the Trash icon that appears in the upper-right corner of the screen. Choose the Confirm Delete command, and the video is gone.
You can't undelete an image or a video you've deleted. There's no way to recover such an image using available tools on the Galaxy Tab.
You can apply the Delete command to an entire swath of items in the gallery at once. To do so, you must know the secret, found below:
  1. Open the album (pile) you want to mess with.
  2. Long-press an image to select it. Instantly, you activate image-selection mode.
  1. Continue touching images and videos to select them.Or you can choose the Select All command.
  2. Perform an action on the group of images or videos.
To deselect items, touch them again. To deselect everything, touch the Done command.
The type of commands you can use on a group of items in an album depends on the group. Some commands, such as Delete and Share, can be performed on any old group. Other commands, such as the image rotation commands, work only with pictures, not with videos.
Apr 26, 2016 | Samsung 7 Galaxy Tab 4 8GB White
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
I am trying to updates to ios 6 on mu IPads
iOS is 8.1.2 now
  1. Plug in your device to a power source.
  2. Tap Settings > General > Software Update.
Dec 19, 2014 | Apple iPad 32 GB WiFi Tablet PC
Factory reset for coby MID7030
Hi Hisham,
I have this site for you on how to reset your device. It includes image as well. Hope it helps.
Hard Reset Procedure For Coby Kyros mid 7030 4
May 01, 2014 | Coby kyros Tablets & eReaders
Toshiba tablet R15-S829 has only c drive .can i do partition in this hard drive. is it accptable for this laptop or not.please help
I think the problem is only that your system crashed. So you can try some data recovery software to recover the wanted data from system partition and then reinstall OS,
I suggest you can use a free data backup software to create a recover disc once you enconter such a problem you can recover your data and system easily.
Freeware AOMEI Data Backuper: http://www.aomeitech.com/aomei-data-backuper.html
Jan 22, 2013 | Tablets & eReaders
How do I install a new HDD and still keep the IBM_SERVICE partition for restoring to factory installation?
If you're replacing the hard drive and want to keep the service partition information, you'll need to clone the disk. You can do this with another computer and a software tool like Norton Ghost, an old copy of Drive Image, Acronis, or some other disk imaging tool. THese tools will allow you to copy the service partition (along with any other partitions) from one drive to another. It's a little more complex than a straight file copy from one drive to another, but it's possible.
Mar 03, 2010 | IBM ThinkPad X41 Tablet PC
HP TC4400 hard drive ugrade problem
go to hp site and check is the model support 320gb hdd or not if not trun yr hdd in limited capisity
Feb 26, 2010 | Compaq tc4400 Tablet PC
Recovery Problems
The Tablets can be quite difficult to perform a reimage or recovery on as most bios versions on them do not recognise a USB device as bootable.
My recommendation would be to obtain a Bootable Floppy disk that contains an imaging program. (GHOST. Powerquest etc).
From here you may have 2 options available to you.
1. Attempt to recover using the hidden partition on your hard drive.
2. Recover from an image located via the network. You will need to ensure that a driver for your network card is also bundled into this install. Once this boothdisk has been created you will need to create a "shared folder" on another PC which contains the image you require. Once the bootdisk has loaded point yourself to the shared folder.
Lastly - You may be able to find an updated bios version that allows boot from USB device.
Apr 23, 2008 | Acer TravelMate C110 Tablet PC
TC1100 onscreen keyboard.
Use a USB keyboard and do a system restore.
Use a USB keyboard to access HP.com and search for a download there.
Use a USB keyboard to backup, reformat, reinstall factory image.Takes longer, but probably best overall fix, HDD may have a few bad sectors and format will fix or avoid them. May be a great time for a 7200 RPM drive and some more RAM! 2Gb RAM and a high speed drive will breathe a bunch of life into a great tablet like the tc1100.
Feb 03, 2008 | Compaq tc1100 Tablet PC
Tablets & eReaders Logo
1,196 people viewed this question
Top HP Tablets & eReaders Experts
Anthony Pattay
Level 1 Expert
tosin_christ
Are you a HP Tablet and eReader Expert? Answer questions, earn points and help others
