Question about EliteGroup 945GZT-M (V1.0) Motherboard
Computer shutting down automatically
After 25-30 mins,current goes out from my cpu suddenly.kindly help what may be the problem?
  • Anonymous Oct 31, 2008
    orange light
  • 781 Answers
Remove case side and clean out ALL fans then remove fan from heatsink DO NOT remove heatsink (probably stuck on CPU) clean all fluff and dust from heatsink.
Use a stiff brush and vacuum cleaner on power supply fan area
then vacuum out case include all vent holes and behind power supply. test start.should be OK
Posted on Oct 30, 2008
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
I love my notebook but all of a sudden its shuts down because it continues to get hot underneath and its not the battery..I log on and it may last 15 mins maybe 45min at the most...what is going on? I
COMPUTER/LAPTOP OVERHEATING
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.http://www.fixya.com/support/r5959377-overheating_computer
Jan 13, 2012 | Toshiba Satellite L455DS5976
Jan 13, 2012 | Toshiba Satellite L455D-S5976 Notebook
I have a 400VTX which will suddenly shut off (immediate... no power down sequence) while trying to use the CD Rom drive OR using a CPU intensive program. I have upgraded the memory to 1MB, used the Intel...
Disable automatic restart on system failure you are probably getting a blue screen
when you first turn on the computer hit f8 until you see an option screen, select disable automatic restart on system failure, post what you find on her so we can help!
Jun 13, 2011 | Gateway 400VTX-3501335 Notebook
Sir i got a viewsonic lcd 19" model 1918 it
Let the unit cool down for 30 min., give proper ventilation because your processor have a heat sensor, once reached the peak temp the unit will automatically shuts off. Keep away all the obstruction from your vent.
Let me know if the symptom is still there...
Thanks for using fixya.
Feb 02, 2011 | ViewSonic VX910 19" LCD Monitor
Sir, my sony vgn cs100E laptop fan is not working, i keep my laptop very clean, but now when i start windows the laptop automatically shutdown after 3 min processing. Fan is not working. what should i do?...
Hello Faiz
OK, the thing is, if the fan is not rotating at all, you will need to replace it. The problem related to the computer shutting down, is the fact that the CPU overheats, and then shuts down the computer to protect the system components.
SO, if the fan actually rotates, you will need to clean the fan from all the dust particles collected on it. If the fan does not rotate at all, you will need to replace the broken fan.
Hope this can be of help.
Kind regards
Andrea
Nov 28, 2010 | Sony CPU FAN CPU Fan
Hi dear, I have one acer veriton 7600gt desktop computer at my home, last night i working that pc suddenly its shut down and when i again start the pc one blue screen is coming and my hard disk is...
looks like old xp machine. power supply could be flaky,bad caps on the board,dust build up on the cpu fan or graphics card causing it to over heat and shut down
Jul 08, 2017 | Acer Veriton 7600GT PC Desktop
Distorted, scratchy sound with Toshiba Satellite
OK, I would restore or recover the computer to manufacturer's original specifications and automatic update to the latest sp3.
Then, I would reinstall your virus protection and see if it's better.
Jul 28, 2010 | Toshiba Satellite A105-S361 Notebook
Why my computer automatically shut down eventhough it working 10 to 15 mins?every time i restart it will shut down again...what is the cause? do i need to replace the new one(motherboard)?
You could have a problem with your OS, it could be viruses, or other things.
It could also be a force shut down by your motherboard. Before you replace the motherboard, check to see if you computer might be over heating. Touch the heatsink on your CPU/Motherboard. Feel if it is too Hot or Cold. You only want it to be warm.
Mar 08, 2010 | EliteGroup P4VMM2 Motherboard
Laptop prob
Check to see if the CPU fan/cooler is clogged or not working. Laptop could be shutting down to keep the chip from frying.
Feb 22, 2008 | Toshiba Satellite A35-S159 Notebook
EliteGroup 945GZT-M (V1.0) Motherboard Logo
50 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
