Question about Black & Decker B2000 Bread Maker
Cannot find out how to set timer for 3 hours for wholemeal rapid bake on machine number panasonic bread making machine sd-255/sd-254
You can't set a timer when you also set rapid bake - the two are not compatible.
If you set it to 'Bake' without the 'Rapid' setting, THEN you can set the timer.
Posted on Dec 09, 2008
Everything seems to be normal but the machine wont knead the dough
If your machine making a sound as if the elecric motor is humming or is it completely quiet?
Mar 13, 2013 | Panasonic SD-YD250 Bread Maker
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
Looking for recipe for rapid rise white bread
Rapid Cycle White Bread
  • 1-2/3 cups warm tap water
  • 2 tablespoon vegetable oil
  • 4-1/2 cups bread flour or regular white flour
  • 2 tablespoons dry milk powder
  • 1-1/2 teaspoons salt
  • 2 tablespoons sugar
  • 2 teaspoons bread machine yeast
Measure the ingredients into the bread pan in the order listed. Make a well in the flour and sprinkle the yeast into it. Set the machine to it's Rapid or Quick Cycle. On my machine this lasts for 80 minutes, or 1 1/3 hours. Press Start, and let the machine work it's magic. Remove the cooked bread from the pan after baking and allow it to cool before slicing.
Jan 20, 2011 | Black & Decker Bread Machine
Bread does not rise enough I have carefully measured ingredients use rapid bake setting fleichmans rapid rise yeast checked water temp still having problems I have tried 4 times regular and rapid rise and...
A few tips.
The yeast must be absolutely fresh, use sachets instead of packets.
Keep yeast well away from the fats and liquids.
The fast rise setting will produce less rise than the full program.
You must only use strong bread flour.
Open lid immediately beep sounds.
Jan 10, 2011 | Panasonic SD-YD250 Bread Maker
My machine was unplugged for no more than 3 seconds during kneading. it is quiet now and on ALERT. on a 5 hour whole wheat xl loaf..now at 3:02. how do i restart it and move it off of alert
If you feel your dough has kneaded and risen enough, try pushing the stop button until it beeps. Then unplug and replug and select the bake stage and using the timer feature put enough time on the bake cycle to equal the bake time of your original whole wheat bake stage. That time should be on your page in the manual that shows the length of all the programs.
Oct 28, 2010 | Panasonic SD-YD250 Bread Maker
Every time I bake a wholemeal loaf, it bakes well enough, but it tapers off to one end. This problem does not seem to occur with white bread, which rises evenly throughout the length of the loaf.
Fast Action Easy Bake yeast is supposed to help with improving the volume of a loaf, but you can add 1/4 tsp of Vitamin C powder (ascorbic acid) to whole wheat loafs to improve the rise. Sometimes mixing the flours helps as a small amount of white (30%) can make the loaf less dense. Make sure you use the best quality flour you can afford - the cheap ones don't always make such a good loaf.
Jul 14, 2009 | Panasonic SD-YD205 Bread Maker
Delay-bake timer not working
I have given you the instructions for the timer for the B2200 and B2250 models. I hope this answers your question. I have also included a link to the manual in case you don't have one.
Carol.
6. Timer Buttons
Press these buttons to set the time for delay bake (up to 13-hour
delay). For example, you can time your bread to be ready for
dinner or when you wake up in the morning. Set it by selecting
how much time you want to pass before the bread is completed.
For example, if it is 8:00 p.m. and you want the bread to be ready
at 7:00 a.m., set it for 11 hours.
You can also use these buttons to adjust the time of the cycle.
They adjust up or down in 10-minute increments. Changes must
be made before the unit begins operation.
http://www.useandcaremanuals.com/pdf/B220,B2250984.pdf
Jan 19, 2009 | Black & Decker Bread Machine
Mellerware 84300 Breadmaker missing manual/user guide
My best results
6 heaped tablespoons whole meal
2 heaped tablespoons strong white
2/3 Teaspoons dark brown sugar
A healthy squeeze of tomato puree (adds ascorbic acid and makes the bead last longer)
Pinch of salt
about 3grams dried yeast
select "dough" (9 on mine)
When the program end bake in an oven at gas mark 5
I have never really been satisfied with a square loaf with the paddle hole in it. Also the bread ends up really heavy. I think this is because the bread sweats rather than bakes
The bread-maker is also easier to clean after just making dough, it produces better dough than i can by hand and the machine gets on with it while i can do something else!
Jul 03, 2008 | Kitchen Appliances - Others
Half sized dish shaped wholemeal bread
Hi
I had a similar problem in making sourdough bread and noted on some websites the importance of correct salt and surgar quantities for rising. I increased my quantities to correct the problem. Of course the recipe was different but it may help.
Jan 28, 2008 | Welbilt ABMIL2P Bread Maker
Kitchen Appliances - Others Logo
131 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
