Question about ASUS Motherboard Striker II Formula
ASUS Striker II Formula Motherboard and SLI Problem
This is the whole scenario:
I have been going insane working on my system and have narrowed the
problem to a video-SLI-memory problem.
My system consists of:
EVGA 8800GTS SSC Edition
ASUS Striker II Formula motherboard.
Intel Q6600 Core 2 Quad 2.4GHz processor.
4 x 1GB Corsair Dominator 1066 memory
A 750 watt power supply
And 3 TB of assorted Disc Drives
After installing the new parts in my existing tower, the first problem I encountered was a intermittent PCIe slot (the first one, naturally). I
chose the third PCIe slot, as it was the only other 2.0 slot. Ok,
video's fine now. However, several USB ports are intermittent and don't
want to settle down. But my computer has been down for more than a week since the 4 year old motherboard died, so I limp along for now.
I continued to limp along until the PC just stopped one day. Rebooting
didn't help, as the system would either hang or fail the POST. Resetting
the BIOS on this motherboard was easy, but during the POST I noticed the
CPU was throttled down to half speed, memory was running at only 800
MHz, SLI memory enabling hangs boot and C1E features hang POST.
I replaced (not repaired) the motherboard and I could now use the first
PCIe. USB ports are stable and the CPU is running at full speed. Memory
and SLI features are still not working correctly. I limp along some more
then order a replacement processor. I replaced the CPU and nothing
changed! It was not until I pulled 2 of the memory modules that
everything returned to normal. Bad memory, right? Not that easy I'm
afraid. The SLI problems only occur with all four modules installed.
None of the modules is defective when used in a 2MB configuration. So it
seems that, after 3 months of messing with this nightmare, there is a
problem with the video adapter addressing 4 GB of memory via the SLI bus
(It used to work fine until that one day). I know of no diagnostics that
test this feature to confirm my diagnosis, but the memory passes all the
usual memory test programs and everything works fine at 2GB. This
addressing problem would also explain the problems I have been having
during POST.
And now.... EVGA's response:
*Answer*:
I am not sure if its a problem with the video card. Sounds like a
problem with memory, more specifically the settings/configuration. SLI
ready memory is a feature that is also known as EPP or enhanced
performance profile. What SLI/EPP does is read a profile on the memory
specifically for the 2 stick configuration it was programemd for and
it changes the speed, voltages and timings automatically in BIOS. The
settings are specifically for 2 sticks only there is no such thing as
a SLI/EPP memory 4 stick kit. When you run 4 sticks of memory you run
the kit out of it's specifications and usually have to change the
settings to accomodate. This could include lowering the speed, upping
the voltage or loosening the timings. Usually this is done by calling
the RAM manufacturer and asking for what settings they recommend. The
reason you can achieve higher speeds with two sticks is because the
motherboards have two memory channels, hence the term "dual channel
memory". When you are running 4 sticks of memory you sacrifice speed
for a larger amount of speed. If you have any more questions on SLI
ready memory let us know. Thanks! EVGA Technical Support
MY response:
Question:
Thank you for the detailed response. Prior to my system lockup, I had no
problems using 4 sticks of the DDR-2 memory. However, after the lockup,
I had to reset the BIOS just to get the system to boot without a memory
failure alarm. That's when I noticed that the system was running at only
1.4GHz (instead of 2.4GHz), memory was running at 800 MHz (instead of
1066 MHz), and only with SLI ready memory disabled. A new motherboard
fixed the throttling problems, yet the SLI memory still had to remain
disabled. A new CPU made no difference either.
If the problem is with a voltage setting (as I have seen with nVidea
chipsets before), why the sudden change? The only items I have not yet
changed are the EVGA 8800GTS SSC Edition adapter and the memory. Since
the memory voltage is controlled by the motherboard, the power supply is
not a suspect. I don't know what to do at this point. I just know that
things were better during the first two months of operation then they
are now.
EVGA's response:
James, EPP profiles are disabled in 4 stick configurations as it is not supported by the memory manufacturer as well as our systems.
Well, what does this group of experts think?
  • Anonymous Feb 28, 2009
    I have the same exact problem and have adjusted the voltage on the memory and the clock speed. I still cant get it to run at the normal speed with 4 sticks and for some reason if the computer goes to sleep it wont wake back up. I turned off all sleep and standby settings in the power options but still have hang issues. Even with the bios adjusted accordingly I can play any game for hours straight but the second i leave it alone for 30 minutes it locks up and requires a restart. The only way i can get it to run with no issues is with only 2x1gb ram.
  • Tyler Flynn May 11, 2010
    Yea it seems like you just have RAM issues. Make sure the RAM is set to the correct voltage and timings recommended for that motherboard. And make sure that SLI memory is turned OFF.
The memory you are using WONT work stable with 4 modules inserted on the motherboard.
According to the Qualified Vendors List (QVL) you are only able to run 2 modules stable.
Got the same motherboard and had the same memory modules (4x1GB) and wasn't able to get them stable as well.
By calling Asus they told me 2 modules max would be stable and 4 wouldn't.
And it was .. 2 modules was stable .. and 4 modules was BSOD's, freezes and hungs everytime! 2 modules was also endless Prime95 stable while 4 modules caused BSOD's after 30 minutes ..
Since Vista kinda needs 4gigs of RAM I bought new memory (OCZ XTC SLI 4096MB (2x2GB) PC6400 800Mhz 4-4-4-15) to solve this issue!
Posted on May 04, 2009
    Problem Solver:
  • 13 Answers
The Dominators are high performance memory. They are spec'd for 2.1 volts, so you must set the DRAM voltage in your BIOS to 2.1 volts, not the standard 1.8 JEDEC specification. Also, make sure you set your latency timings to the following:
5=CAS Latency=TCL
5=RAS# to CAS# Delay=tRCD
5=RAS# Precharge=tRP
15=RAS# to Activate to Precharge=tRAS
Command Rate 2T
These settings should automatically populate in one of your EPP profiles.
-E
Posted on Mar 04, 2009
ErrorM56
A branded computer uses Original Equpment Manufacturer (OEM) version of Operating System, hence if you change any hardware it will go to the trial version of OS automatically. Hence, you have to use the full system recovery disk to reinstall the OS.
Thanks and regards,
Nov 13, 2010 | ASUS Motherboard Striker II Formula
Models of motherboard with socket 775
To many to name but here are a few.
Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboard - Socket 775, ATX, Audio, Video, PCI Express 2.0, USB 2.0, RAID
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0
EVGA nForce 750i SLI Motherboard -NVIDIA nForce 750i, 45nm Support, Socket 775, ATX, PCI Express 2.0, SLI Ready, Gigabit LA, USB 2.0, Serial ATA, RAID
Jun 01, 2010 | ASUS Maximus Formula Motherboard - 45nm...
L am running a 650watt power supply with 2 engtx 260 pcie cards and a e8400 pentium on a 64 vista ultimate os that is hanging on start up and even if i get it to boot within 5 minutes of running the pc...
The most common causes of your problem are memory and video. 1st thing is to hit F8 and see if your system has an option to halt on all errors. This should cause you to see the blue screen of death if you don't already. It will give you an error code followed by a file name sometimes. If a driver is causing this it will tell you the driver name. This option only works on some systems. The second thing I would try is running Microsoft's memory diagnostic in the extended mode. It runs like 11 tests. http://technet.microsoft.com/en-us/magazine/2008.09.utilityspotlight.aspx?pr=blog
You could also try taking your ram out and running one stick at a time and seeing if the system locks.
Dec 06, 2009 | ASUS Motherboard Striker II Formula
Where can I get a manual in ENGLISH ((~: Striker II formula T3472
From the manufacturer's web-site, you can download a "multiple languages" version:
http://www.asus.com/Product.aspx?P_ID=wOFZuyplXj0vLmAc
Select the "Download" tab.
Select "WinXP".
Expand the "Manual (16)" branch of the tree.
Select the specific model ("T3472").
Select the "Multiple Languages" version;.
Nov 05, 2009 | ASUS Motherboard Striker II Formula
Asus Striker II Formula
try to boot up with minimum configuration ie: graphic card , and memory, check BIOS configuration
Sep 25, 2008 | ASUS Motherboard Striker II Formula
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
2 much memory?
First make sure your motherboard can handle the size memory stick you are attempting to install, find out the Max amount of RAM the board can handle per slot. If you are within the range then do a memory test after it is installed to see if the memory is good or has issues. Check out http://www.memtest86.com/ for a bootable memory test program.
Jul 10, 2008 | Computers & Internet
ASUS STRIKER FORMULA
This Is A Processor error Message, CPU ( Central-Processing-Unit ) INT ( Intermittent Fault ) wrong Type Installed. ( Faulty Processor ) Disconnected Fan-Wire To Motherboard ?
Or if It,s INIT Then It Fails To Initialise The CPU.
Is The Board Auto-detect Settings ? Or Jumpered ?
Mike @ Compurepair.
** Please don,t Rate This Post until Your Problem/Issue Has Been Resolved**
Feb 27, 2008 | ASUS Striker Extreme Motherboard
Need wiring harness guide for asus p5n32-sli deluxe motherboard
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5N32-SLI%20Deluxe
You can get all the files you need here.
Download and print only the parts of the manual you need or it will be almost a whole stack of paper.
Good luck with this mobo.
I've had nothing but prob;lems with it.
I'm going back to my ecs that I know works.
I suggest you search "problems with p5n32-sli".
Oct 18, 2007 | ASUS P5N32-SLI Deluxe Motherboard
ASUS Motherboard Striker II Formula  Logo
917 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
