Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
How do I remove old printhead and install a new one?
How do remove old printhead and install a new one?
  • 22 more comments
  • Anonymous Oct 29, 2008
    I have the same problem. How do I remove the old printhead and install the new one. When I received the new one, there was a paper that instructed me to go to www.kodak.com/go/printheadsupport which I did and I found nothing. This has not solved my problem. Help
  • PacmansLady Nov 05, 2008
    how do i take out the old print head
  • Anonymous Nov 09, 2008
    Yes, I have the same problem.
  • camerondtrt Nov 12, 2008
    install new printhead
  • Anonymous Jan 08, 2009
    esp3 they sent replacement printhead with no instructions
  • Anonymous Jan 09, 2009
    I need to remove the old print head from my Kodak Easy Share 5300
    I need to know how to remove the old print head
  • Anonymous Jan 10, 2009
    yes
  • mosey68 Jan 21, 2009
    Hi I have same problem. I can't get the print head out. There is not instructions how to remove it It just said remove printhead Can you help please ?
    -+ Maureen+
  • mcclure1970 Jan 22, 2009
    Yes I had the same problem, but I went to the following website and got the installion information for free (kodak.com/go/printheadsupport)
  • roblines Feb 07, 2009
    roblines@earthlink.net:
    Several people seem to be asking how to remove the printhead from their Kodak Printer. I have a Kodak Easy Share 5500 Printer. I, also, cannot figure out how to remove the old printhead to replace it wiith a new one. HELP!!!
  • Anonymous Feb 17, 2009
    can not receive fax
  • illiahow Feb 18, 2009
    On my two month old Kodak ESP3 printer my printer head quit working. I called and they sent me a new printer head but i don't know how to install it.
  • jstarkey6 Feb 26, 2009
    need to replace printhead on my kodak easyshare 5300
  • Anonymous Feb 28, 2009
    HOW DO I INSTALL THE NEW PRINTERHEAD IN MY KODAK 5500 PRINTER
  • Anonymous Mar 15, 2009
    I need to replace my printhead
  • whitejw101 Mar 27, 2009
    how do i take my old printerhead out to put the new one in. this for a 5100 easyshare all in one.
  • zoolady1954 Apr 01, 2009
    How do you install a new print head
  • cathy tielemans Apr 03, 2009
    How do I change head? on kodak ink jet printer
  • rbeharry1 Apr 18, 2009
    how do i change printhead on 5500
  • Anonymous Apr 25, 2009
    how do i change out the printhead on my 5300 printer
  • Anonymous Apr 29, 2009
    remove old printhead install new one
  • brudunn Apr 29, 2009
    It refuses to print documents with black print. This has been going on for a while. Ink changed twice. Any suggestions besides throwing it out the window?
  • RJFOSTER55 Sep 15, 2009
    I HAVE TAKEN THE OLD PRINTHEAD OUT OF PRINTER BUT NOW CANNOT GET THE BUTTON HELD UP TO GET THE NEW ONE IN....
When you get the cartridge,s out of the tray. Look at the tray and locate where your finger is on the bull eye.. Right above the sticker there you will find a small tab under the top ledge you need to press the tab upwards and the tray will come out.... replacement is to reverse process
Posted on Mar 15, 2009
  • marcilong Oct 19, 2010
    Thank you. This is the solution that worked for me. Thumbs up!!!!! Now I am off to see if the product works. Thanks again for your instructions. Marci Long
I did not see the bulls eye, as there was not one there when we bought the printer;
But just get a flashlight, there will be a little and I do mean little button at the very to of the tray. you almost have to put your head into the printer to see it. Push that button up firmly but not try not to be to rough with it, lets face it this is a sensitive printer.
Pushing this button up will release the tray, and you will be able to pull it out.
Posted on Nov 12, 2008
After removing the ink cartridge feel above the bulls eye sticker thier is a release button it took me a while to find it hope this helps
Posted on Nov 01, 2008
I have the same promblem
Posted on Jan 16, 2009
I have removed the ink jets and the print head twice and reincerted them. It keep telling me to do this over. Now What?
Posted on May 04, 2010
How do i remove old printhead and installa new one?
Posted on Sep 10, 2009
How do i replace the new printhead kodakESP5
Posted on Jun 12, 2009
Posted on May 11, 2009
3 Suggested Answers
  • 20 Answers
SOURCE: How do I remove old printhead and install a new one?
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Posted on Mar 25, 2009
  • 43 Answers
SOURCE: how do i remove old printhead and install new one
Replacing the printhead If your printhead is damaged or broken, you may replace it yourself.
  1. Make sure your printer is turned on.
  2. Open the printer access door by lifting from the recessed hand-holds on the sides of the unit. autourg00977009id2130369.jpg
    The printhead moves to an accessible position for handling the ink cartridges. The ink cartridges are seated in the printhead.
  3. Pinch the latch on the ink cartridge with your thumb and forefinger and lift it out of the print head. Remove both ink cartridges.
    caution.gif CAUTION:
    Insert the ink cartridges into the newly installed printhead as soon as possible to prevent any drying of the ink.
  4. Unlatch the printhead by lifting the rectangular latch on the top of the printhead.
  5. Remove the old printhead from the carriage .
  6. Remove the new printhead from its bag.
    Do not touch copper contacts on the printhead, as this may damage it.
  7. Remove and discard the black plastic casing and the orange protective cap.
  8. Place the new printhead into the carriage.
  9. Push firmly against the target label on the printhead until you hear it click into place.
  10. Re install the ink cartridges. As needed, see Replacing ink cartridges.
  11. Close the printer access door. The printer should now complete a printhead calibration to ensure that it is ready to for normal operation.
Posted on Nov 23, 2009
How so I remove the old prinhead and install a new one
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. Scroll to the Printhead menu icon (icon on the lower right of the front panel display) and press Enter.
  4. Scroll to Replace Printheads and press Enter.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. When instructed, open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts in all carriage slots and on all printheads (instructions below).
  10. Allow the contacts to dry.
  11. install the new printheads and close the carriage cover.
  12. Close the top cover.
  13. Turn the printer on and attempt to verify functionality.
Apr 18, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have new printhead.
First, go to Canon i9900 Support
If the Support & Service tab is not selected, click on it.
In the search box type reseating printhead and click Search.
One of the results will be "How do I reseat/remove the printhead?"
Click it. A step by step (with animation) will be shown. Just install the new printhead when it calls to reseat the printhead.
Make sure you do the printhead alignment after installing. if you are unsure about how to do this, go back to the support page above and search for align printhead. There will be step by step instructions for this too.
Thanks for using Fixya.
Dec 03, 2009 | Canon i9900 InkJet Photo Printer
How do i remove old printhead and install new one
Nov 23, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
New Printer - Issue with installing printhead
first of all.. make sure that you remove the packing material from the cart or print heads and put them in properly.
then also if it it gives the same probem then try it with the old print heads.. if it doesnt gives any eror with the old ones then replace the new ones..
new ones are bad..
return them to store
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
How do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Jun 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have the new printhead for my 5500 All In One. Your instructions tell me to go to kodak.com/go/pintheadsupport. When I do this, it tell me I can find instructions and pictures explaining this by choosing...
remove the ink. on the left side of the printhead (the old one) there should be a button you can depress near the top. push it and the printhead should come off. put the new printhead on and push it where there is the sticker until it clicks into place. remember! take off all the things on the new printhead. I think it's orange?
Jan 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Jan 24, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do I remove the old printhead and install a new one?
remove both ink cartridges. on the top of the printhead, near the left there is a button. push it and the old one should come out. to put in the new one take all the protectors off and push it in where the old one used to be. push on the thumbprint until it clicks and reinstall the cartridges.
Jan 18, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Remove printhead
please don't repeat post as i said before, remove both ink cartridges. on the top of the printhead, near the left there is a button. push it and the old one should come out. to put in the new one take all the protectors off and push it in where the old one used to be. push on the thumbprint until it clicks and reinstall the cartridges.
Replacing printhead in Kodak 5300 All in One Printer
on this website:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
You can find illustrated instructions on how to remove the old printhead, as well as on how to put the new printhead back in place.
You can easily go to that website by going to:
and selecting the second option "installing new printhead".
Nov 05, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
5,000 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
