Question about Fisher and Paykel GWL11 Top Load Washer
The drum won't spin-
At first the drain pump did not work until I freed it up. Now the pump i sworking but the drum won't spin. I laid it on it's side to look at the pump- would that affect the drum spinning
  • Anonymous Oct 29, 2008
    went through the wash cycle ok, butwill not spin, just beeps
    President:
  • Fisher and P... Master
  • 2,651 Answers
The drum wont spinn with wate in it(very fast anyway). if you remove the agitator, the inner tub lifts right out(its a floating basket) perhaps an article of clothes has gotten below it preventing free floating of the tub. While out ive als seen where the metal spline/shaft has worn down the plastic counterpart and the tub has nothing to grabonto to allw to spin, the sppline and plastic counterpart are very apparent after removing the agitator, they sell a spline repair kit(new spline and holder (3 screws) easy repair.
Posted on Nov 02, 2008
Run diagnostic test gltf2940es0
if the drain pump is bad or clogged and can't drain the water it won't spin until water is drained.pump number 137221600,it's around 110 dollars,but first get a shop vac,pull out the drain hose from the washer and connect the shop vac to the hose and vac out all the water,you first have to remove the bottom front panel to get at the pump,remove the hoses going to the pump and have the vac ready to clean up any water that still might be in there,then check the pump and see if anything is in there,i've found coins that get into the pump or other debries and clean it out of the pump,then check the rubber boot on the hose,make sure nothing is in there and check the other hose,you can set the shop vac on blow and blow through the drain hose to make sure that's clear,remove any junk you find in any of the hoses and pump,reconnect the pump and hoses,put some water in then set it to drain and spin or rinse and spin,if the water drains and then it spins you're all set if not the pump could be bad,one more thing if the drum doesn't move you could just have a bad door switch,this is the easiest part to fix and i always have a door switch for frigidaire washer,remove the spring the holds the boot seal on.remove the rubber boot on the door switch side,take out the screws that hold the door switch in,and replace it,run it,if the drum starts to move then drain and spin it was the door switch,any error codes come up? good luck,have any questions let me know and hopefully i can help you
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
My washer won't drain the water when it spins to rinse cycle and it won't drain when it's on the spin cycle
there is a screen that needs to be cleaned out on the bottom under the wash drum
Jan 15, 2013 | Washing Machines
Samsung WF7700N6W1 washing machine not draining
Could be a sock or something between the 2 drums that moves over the outlet hole from the drum when upright and trying to drain but moves away when machine is on its side. Get a flashlight and look through the holes in the inner drum and you may find the culprit.
A coin may also be stuck in by the pump blade, not always easy to see but worth a look.
Dec 22, 2012 | Samsung Washing Machines
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Water pores out on spin
Take off the cover and check for any holes in the top of the plastic tub surrounding the drum . This can occur when the washer is or was previously severely out of balance and the drum rubs a hole in the side of the tub. Since the water is usually below this level until the spin cycle pushes the water up the sides of the tub, it only becomes apparent then. Another possibility is there may be a blockage in the pump or drain hose. If you still have a good amount of water in the tub due to the washer not draining completely before the spin cycle, the water will sling everywhere when it attempts to spin. I hope this helps! Good luck!
Feb 21, 2012 | Washing Machines
My washer won't spin on spin cycle
Hi rapwizz,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Whirlpool Washing Machines
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
Pump runs but nothing is pumped out
I just had a tech over,have the same problem with my SHE45M. Was told the plastic impeller is spinning on shaft. New to replace the drain pump.
Oct 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Fisher and Paykel GWL11 Top Load Washer Logo
180 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
