Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp Copier AR-5132
We have an old Sharp Copier AR-5132 and no longer have the manual. A message comes up "call for service" and "F1". Is there any way of fixing this on our own because the warranty has been up for years. Even if we cannot fix it on our own, just knowing what is wrong with it will be extremely helpful. Maybe we just need to clean the inside of it and reset it somehow.
Thank you
  • Tim Babcock
    Tim Babcock May 11, 2010
    There should be two more numbers after the F1. Press the start button and see if they pop up.
    Then I can tell you what is wrong.
  • Sharp Master
  • 2,794 Answers
It is the finisher alright but on a Sharp machine there are six types of codes associated with an F1. You can tell by the last 2 digits after the F1 code:
  • 00 = Lost communication with the sorter.
  • 02 = Paper transport motor overload
  • 04 & 05 = Bin sorter position error
  • 06 = Shift motor overload
  • 08 = Stapler position error or overload
The first thing to check for is any paper jams in the finisher. Check the stapler cartridge for any binding.
Posted on Oct 31, 2008
    Problem Solver:
  • 13 Answers
Generally F codes have to do with the finisher(used to be called a sorter). with the machine off, diconnect the finisher cord from the copier and power back on. This should allow you to test the copier. I'm not sure on this model how exactly the finisher cord comes out. but it should be self explanitory when you see it.
Posted on Oct 29, 2008
How do resolve f1-06 code on my sharp 5132 copy.
I understand it is shift motor overload.
Please help
Posted on Jun 25, 2010
How to fix over heat error message?
www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Jun 11, 2015 | Sharp Copier Toner AR-5132 5125 AR-532NT1
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Looking for part number for Sharp AR5132 polygon motor
Ploy for the AR-5316 copier is RMOTN0022QSPZ
AR-5132 I think I still have the parts guide at work will look next week. I may also have a pulled working laser unit. I can check with my office for a price if you want and if I can find it.
Nov 18, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp Ar-5132 U6 code after moved the copier
U6 code indidcates a laser problem. It may have been shaken or bumped a little too much in the move.
Jul 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error U3 on a Sharp AR-5132 Copier
The problem is on the mirror section on the scanner unit. It might be the motor, sensor, scanner wire or just need lubricating. I think you better call your local tech.
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5132 copier won't copy, no error message
okay start by loading a piece of paper on the glass and choosing maual feed and placing a sheet of paper in the manual feed tray and press the start key and see what happens. also on some of the sharp copiers there has been a problem with the print button itself, so i don't know if that may be the case.
Thank You,
Mikey
ps let me know how you make out.
Apr 06, 2008 | Office Equipment & Supplies
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
607 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
