Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Rinnai 431wt my heater is set at 72 degrees. how to set to 78 degrees. when depressing stays to 72 won't go beyond.
  • mandlross Nov 22, 2008
    I have a Rinnai Energysaver 557FTR and I want to know how to adjust the temperature.
    I just bought the property and have no instructions manual.
Bad thermastat
Posted on Oct 29, 2008
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
How to reset the thermostat to shut off after 2 degrees/CT87B-4008?
on these thermostats remove the outer ring cover and in the lower right side you will see a slide adjustment. move it i believe left for closer cycles and right for longer cycles. it should be 2* on either side of set point. remember that the fan is not furnace shut off.and turning back and forth will not tell you anything. just set it and see how it works then change it again if you need to
Oct 13, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
The temp setting shows 78 degrees,lower to 72 degrees /it stays for 15 sec and returns to 78 degrees no codes
you may not be giving the a/c enough time to cool down to 72 the reason it goes back to 78 is that is the temp in the room at that moment put on 72 and give it about 20-30 min. to see if this helps
Jul 03, 2011 | Sharp AF-S120FX Air Conditioner
Have a 1004fa model to heat a room. temp on
You may have a bad circuit board. Depending upon the age of the heater it may still be under warranty. Contact Rinnai (in US) 800-621-9419 with your serial number and installation date. Ask if they can offer a solution. Good Luck!
Jan 13, 2010 | Rinnai Heating & Cooling
Heater not heating at the right temperature?
Sir,
Your heater is only a 21K BTU heater. It is not meant to heat a whole house. We don't know how big you house is, however a 21K heater will not heat 4 or 5 rooms. The best you could expect out of a Rinnai 556 would be to heat a couple of rooms that are next to each other. You will never be able to heat rooms in your house that have doors or are down the hall a ways.
Good luck,
Tom Hawkins
hawkins111@gci.net
Apr 21, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Rinnai 431WT blinking53
Wooden,
You have some problem with the spark. Either it didn't come on or it stayed on longer than it should. Try to start the heater and look into the burner you should see a spark in the pot.
Tom Hawkins
hawkins111@gci.net
Apr 09, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai 431wt filter light won't go out
If you have changed the filter, and the light stays on then you need to let the system stay down for 24 hours without running. Also go ahead and check the vent cap on the outside of the unit. The light will go awaa by itself if you need to use the system
Feb 08, 2009 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
220 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
