Question about Senco Tools & Hardware - Others
Senco stapler piston will not return & the bumper is like new
    Problem Solver:
  • 10 Answers
Not much to go on there. As the plunger makes it's attempt to return, is there an increase in exhaust pressure? What I'm getting at is that there should be 2 sets of O rings. One for downward force and one for upward. Are both sets sealed tight? Are they lubed porperly? Could the cylinder wall from which the plunger functions be warped or defected in anyway? I'm just throwing this one out there so please don't be offended...Are the O rings the proper size?
Posted on Nov 05, 2008
Paslode stapler
Several things to check for piston not returning to top of cylinder. Most common problem is bent/ broken driver. Worn oring on piston is second most common. Piston should move easily in cylinder but hold in place. Point nose of gun up then down again, if the piston moves within cylinder, replace the oring. Lower bumper and washer with slot under the bumper must be in good condition. If the bumper is cracked or missing pieces and or if the washer fits too loose around the driver blade, the piston may not return to top. Finally, pull out the cylinder and make sure that the check-oring is in place around a series of holes on the middle to lower part of the cylinder (small groove cut into cylinder with several small holes). Good luck with your repair
Jun 05, 2012 | NRS Paslode T250-f16,s200-s16 Nailer &...
The problem i'm having is with a senco sn 41 stapler the driver wont fully return to the top
Hello try to put some oil in the connection of top and bottom may be this might help. please rate my comment
Nov 21, 2011 | Tools & Hardware - Others
How do I adjust the depth of the nails? I have the Senco FramePro 601.
Most senco nailers have an adjustment on the lower safety. Usually one or two screws allow foot to extend. Others framers have a thumb wheel on the side or under the trigger. If the adjustment is all the way out and the nail is still setting too deep, then fault may be with the lower bumper. If the bumper is breaking up, the driver will set the nail too deep. Remove head and pull the piston, if the bumper is missing pieces or cracked, replace. Good luck
Apr 22, 2011 | Senco Air Tools & Compressors
Why won't the driver retract on my pneumatic stapler
Can't be more specific without model number.
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snugly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band or one or more orings and fit in groove/s with row of holes (make sure holes are clean). Other problems related to driver not returning is/are lower bumper is missing pieces or cracked and or air exhaust port is restricted, low air pressure. Parts are available at www.toolpartsdirect.com
Mar 28, 2011 | Senco Air Tools & Compressors
Sns45xp senco dosent shoot anl leak air for the cap
You have worn or broken o-rings in your upper firing and trigger system. You need a Senco repair kit #YK0230 to fix your problem. Fairly easy to do, replace one o-ring at a time to make sure you get them back in place properly and use the grease in the kit liberally. Since you'll have it apart I also recommend you get Senco repair kit #YK0231 which is the lower seals and piston stop. If the upper rings are going bad the lower rings won't be far behind.
Feb 03, 2011 | Senco SNS45XP 16Gauge Construction Stapler
I have a SCN40R gun that doesn't advance the nails in the coil part. What could be the problem. The part that is suppose to advance the next nail doesn't move.
The feed pawl is moved by a piston that extends from a cylinder on the lower side of the guide body. There are a couple seals inside the cylinder that if damaged will not hold enough air to activate the piston and advance the next nail. The two seals are Senco part number LB0828 & LB0845. Better yet get a Senco YK0369 repair kit and replace all of your o-rings, you'll have a like new gun for around $60.
Jan 06, 2011 | Senco Air Tools & Compressors
I have a Senco MII Roofing Stapler and the Driver will not return what do I do?
air operated stapler/nailer. there is an air leak in the lower chamber. get an o ring rebuilding kit.
Oct 13, 2009 | Senco Tools & Hardware - Others
Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
Apr 09, 2009 | Tools & Hardware - Others
Senco SFN1 wont work
I have worked on many sfn1 with the problem that you describe. Here are a few things to check. Driver/piston too tight or too loose in cylinder or bent. It should be relatively easy to move the driver piston up/down the cylinder. Usually it should hold it's own weight and not drop down the cylinder. There is a washer that should be at the bottom of the gun under the bumper (washer part# bf0070). This washer must not be worn to the point that too much air will leak past or missing. Finally there is an oring that controlls return of piston (part # lb0077). Pull out the cylinder and find it located on the outer part of the cylinder close to bottom. Clean the port holes under the oring and make sure that the oring fits snuggly. Do not use oil in this gun. Oil will swell the rubber parts. I use silicone lube available form Lowes in the plumbing department. The grease is used to lube faucet orings. Good luck with your repair and email if you have questions.
Mar 16, 2009 | Senco SNS41 16Ga Stapler 1" 2"
Narrow crown stapler won't fire
If the gun has never been opened, the problem could be a lack of oil or worse, too much of the wrong kind of oil. No oil causes parts to stick. Too much of the wrong kind of oil caused the orings to swell and jamb parts. Carefully open gun to preserve head gasket and check for piston travel all the way down to the bumper. Piston should not be too tight, nor drop to the bottom under its own weight. The driver has a groove on one side that should align with the grove in the nose and it should not be bent. Next check the head valve by pushing the valve into the head with your thumbs. the valve should travel about 3/8 inch. If stuck apply air pressure to hole where gasket sits on head. The valve will pop out. Clean and lube parts replace orings or upper bumper if cracked. Assemble and test. Parts are not expensive at www.toolpartsdirect.com, enjoy
Nov 26, 2008 | Senco SNS41 16Ga Stapler 1" 2"
Tools & Hardware - Others Logo
144 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
John Bowen
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
