Question about Kenmore 63942 Dryer
Help i have a electric dryer and will not turn on close door and push button i have checked the circut breaker on luck
    Genius:
  • 1,122 Answers
Most of the time it is the door switch that goes bad or the main fuse on the blower box inside fails,you can also check to make sure the dryer wall vent hole or dryer hole is free and clear,let me know what you find-mike
Posted on Oct 29, 2008
How many sensors to test dryer door switch, one or two?
the female is the switch! you can pop the top off and check with electric tester on ohms, make sure you unplug the drye
check the breaker make sure you have 220 volts a in the outlet !
Aug 15, 2017 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Push start button dryer runs 1 second. Hold start
HI! The Push To Start Switch is defective. Click on the following link to order a replacement switch. !http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3977456/0026/110/Model-11063952102/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11063952102&subCompDesc=Top%20and%20console&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&pathTaken=partSearch&blt=11 for only $9.96. If you have a SEARS store closed by, you can get it from them.
To install, check the diag. on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11063952102/0582/0151200/P0211134/00001?blt=06&prst=&shdMod=
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 08, 2010 | Kenmore 63952 Electric Dryer
Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Jul 24, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have an Admiral electric dryer that is 3 years old. Earlier this evening I dried a load of clothes and when I reloaded it again, it will not come on. The interior light will come on and the door switch...
the dryer has a overload type fuse that blew out the wiring diagram might show you where but it should be either on or near the motor and also check the switch contact where door closes....
Oct 16, 2008 | Dryers
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Kenmore 90 Series Electric Dryer will not run
Listen very closely to the dryer right as your pushing start.Is there any sound at all.Listen very closely because its critical on making the diagnosis.
May 21, 2008 | Kenmore 62602 Electric Dryer
Won't work at all,
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Nov 02, 2007 | Whirlpool LER5636P Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
