Question about Nextel i860
I850 lcd my old screen was cracked and replaced both the lcd and flex cable. when i start the phone the keypad will light up everything is fine but nothign shows on the inner screen and only the upper half of the caller id screen lights up
    Problem Solver:
  • 5 Answers
Your software is screwed you either need to reflash it or get a new mother board. www.cdphonehome.com Nextel Repair Parts
Posted on Jul 25, 2007
The internal screen on my LG Env Touch remains blank after opening. The interenal keypad lights up when opened, but not the screen. The phone did not get wet, to my knowledge, and was functioning properly...
Hi, most screen problems usually happen after a fall or a knock against a solid object. There are two things that might have happened here. One might be, the screen got a hairline crack and the connection to the lcd is broken. The other is that the lcd did not crack, but the connector flex cable is disconnected. The first requires a replacement lcd. The second requires an inspection to see if the flex is disconnected or broken. (You will have to open the phone). If you cannot DIY, then take it to a repair shop. Replacement lcd can be found on ebay.
Jul 09, 2011 | LG enV Touch VX11000 Cell Phone
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Razor v 3 keypad will not light up,everything else is fine
Hi,keypad light issues for Motorola phones are usually caused by the flex of the phone and also the Keypad IC.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
also When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Hope it helps.
Thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
Keypad is lighting up but not the screen ,sometimes it goes on but not for too long.everything else works perfect but the screen does not light up,Ive tried the Sony Ericsson software to but repair .what...
hi,
try to dial 112 or any emergency number in your country ..if you HEAR nothing it is software problem ,but if you HEAR something it is either LCD (glass display in your screen ) or FLEX cable (it is the component that makes your phone display functioning..you can do it by yourself if you have a tools called T5 that you will used to dismantle your phone ...buy an LCD that compatible to your phone and also flex cable...here is the guide to dismantle your phone...http://www.youtube.com/watch?v=WPCDM0tvMRM
i hope it will help you ,thanks for trusting fixya
Feb 22, 2011 | Sony Ericsson K850i Mobile Phone
Replace flip on my nextel i850 phone.
1. Remove battery cover and battery
2. Remove the four T-6 screws from back of the phone (you will have to raise the antenna to access one of them)
3. Seperate the housings.
4. Disconnect the flex connector/data cable that connects the back housing to the motherboard.
5. Disconnect the cable attaching the flip to the motherboard (at top of board)
6. Remove keypad from old part and put it in the new part.
7. Insert motherboard into new flip/front housing and connect cable to board.
8. Reconnect cable from back housing to motherboard
9. Replace and tighten 4 screws and you are good to go.. very easy repair.
Mar 24, 2009 | Nextel i850
My screen is black but my phone works other wise...i cant seem to find a way for it to change. i've switched batteries and charged it but its just i cant see jack on my screen.help?????
good evening !   the problem of your phone is LCD liquid crysta display, or flex,try to replace that,good luck for your i850,thanks
Nov 12, 2008 | Nextel i850
I CHANGED THE COVER (6131) AND NOW MY SCREEN GET OUT FROM ORDER
your screen dosnt display anything?I am not quite sure what your asking but ill take a crack at it anyway.you changed the housing and when you put the phone back together the lcd stoped working,if this is the case you either disconnected your lcd or you damaged the flex cable to the lcd,either way you need to open your phone back up just the top part where the lcd is,you should beable to see the flex cable coming from the phone to the lcd if it looks connected disconect and reconnect and try it if this does not work you may need a new flex cable wich means that you may have to get a whole new keypad cause the flex cable usually only disconnects from one side,well good luck
Sep 23, 2008 | Nokia 6131 Cellular Phone
V3x does not start
Hi
what do mean? the phone turn on then shut off? did you see the light in LCD Screen?
Thanks!
Sep 12, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Help w850i wsod
have the flex cable replaced....
Dec 06, 2007 | Sony Ericsson W850i Cellular Phone
LCD Screen Fried
Flex cable could be torn. This was the problem when I took my phone apart.
Oct 09, 2007 | Samsung SGH-t629 Cellular Phone
Cell Phones Logo
46 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
ray gallant
repairphone
repairphone
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
