Question about Brother IntelliFAX 2800 Laser Fax
Fax prints to dark
I have changer the toner to my fax machine and it still prints to dark
density setting is at minimum and contrast setting is at minimum. I have no drivers for fax machine. what should the setting be at for copy and fax and density and contrast. please help.
  • dmd1170 Jan 23, 2009
    We also have dark print. We changed the cartridge and now everything that prints from our Brother Intellifax 2800 Laser is dark over the whole page. It looks like it is toasted, like the old thermal paper would turn when it got hot. I tried lowering the contrast and turning on the toner save feature. The pages still come out dark.
  • Anonymous Jan 23, 2009
    first page prints fine, every successive page is darker and darker until it is completely unreadable, this usually takes about 4 pages.
    Champion:
  • 320 Answers
Have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Posted on Jan 16, 2009
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
I need to lighten print on my richo2210L fax machine
To adjust the contrast, Press Darkness. Each time you press the button, the LED labeled with the selected mode turns on. You can choose from the following darkness modes:
1>Lighten: works well with dark print.
2>Normal: works well with standard typed or printed documents.
3>Darken: works well with light print or faint pencil markings.
Dec 07, 2011 | Office Equipment & Supplies
Why are all my incoming faxes all black pages?? Is it my fax or the senders? Very hard on the ink cartridge
hard to determine the problem without any make/model of your fax machine. However I would begin by looking at the fax contrast and darkness settings, they are likely cranked to the dark side. If you cannot find these settings or this doesnt help. post your make/model information. I don't believe this should affect sending faxes, its likely just a print / contrast setting for received faxes.
Aug 29, 2010 | Office Equipment & Supplies
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Toner prints to dark
hi!!!!!
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
lighter.
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Printing Faxes
try another drum unit.
Jul 02, 2008 | Brother MFC-8220 Fax
Brother HL 1440 Printer Density Adjustment
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
Feb 08, 2008 | Brother HL 1440 Laser Printer
Ricoh FAX2900L printing too dark
check the scanner white roller witch is under the front cover where you feed in the paper to be scanned sometimes this gets dirty you can take it out by releasing the levers on each side..this also sets the density for copying.. if you have just put a newe cartridge in also check that it is seated properly as the contacts for the charge might not be connecting properly
Nov 08, 2007 | Ricoh FAX2900L Plain Paper Laser
Brother IntelliFAX 2800 Laser Fax Logo
209 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
