Question about Haier HTE18WAA Top Freezer Refrigerator
HAIER HTE18WAA The freezer motor will not stop running. I am getting lots of frost in my frost free freezer. Refrigerator seems to be working fine.
  • 2 more comments
  • Anonymous Nov 09, 2008
    I have the same problem - the compressor never turns off
  • beatrix563 Nov 09, 2008
    I have the same problem with my Haier 20.7 Cu. Ft. Frost Free Top Mount - the compressor never turns off
  • mabajada Feb 13, 2009
    I have the same problem with a HTE16WAAWW.
    The Freezer is so badly frosted it doesnt cool the fridge. The unit is only a few years old and It's already been 'repaired' once
  • Anonymous Mar 02, 2009
    The Freezer is completely frosted over. Just started last week.
    An expert who has written 3 tips or uploaded 2 video tips.
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
The thermostat that controls when the compressor needs to run has probaly quit.
Posted on Oct 29, 2008
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Nov 16, 2011 | Haier HTE18WAA Top Freezer Refrigerator
Frezer is cold refrigerator is warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Dec 09, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Haier refrigerator freezes in freezer but does not get cool at all in the cooler section
my refridgerator freezes too much in the freezer and does not get cool in the cooling section
May 30, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Freezer works fine, refrigerator does not chill
Refrigerators draw air from the freezer to cool them. There are several possibilities. First check to see if you need to defrost the freezer, this can cause a blockage stopping the air to the refrigerator also make sure that there is nothing blocking the air flow in the refrigerator.
You can set the freezer colder and turn up the refrigerator setting dial.
If these don't work it could be the fan that is supposed to circulate the air to the refrigerator is not working. The door switch for the light often turns the fan off while the refrigerator door is open.
If the items in the freezer aren't frozen hard then you most likely need you system recharged or there may be something wrong with the compressor.
Mar 26, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Our freezer seems to be working fine, however, the fridge part doesn't seem to be cool at all
all you have to do is defrost the frige the freezer sometimes will freeze up with ice in the back of freezer where the air flows into frige
Mar 13, 2010 | Haier HTE18WAA Top Freezer Refrigerator
Refridgerater doesnt get cold enough.
Things to check.......Is the evaporator (freezer) fan motor running? If not you could have a bad motor
Do you see a build up of frost on the interior rear wall of the freezer? Problem in the defrost system. This includes the heater, terminator or control.
In addition a bad fresh food damper control or blocked return air duct could be restricting airflow into the fresh food compartment.
Ideal temps should be 0 to 10 above in the freezer and 36 to 42 in the fresh food compartment. This can be measured by submerging a thermometer in a cup of vegetable oil that has been in the freezer for 24 hours. The same can be done in the fresh food compartment where a cup of water will do the trick. Higher freezer temps could indicate a more serious problem in the sealed system.
Apr 28, 2009 | Haier HTE18WAA Top Freezer Refrigerator
The outside metal around the freezer area is very warm.
We were informed that because of a lot of power outages and surges that the freezer was in constant defrost mode. Since the freezer had been in constant defrost for at least 5 days, we were told that the condenser would probably short out. Even though the fridge was 7 years new. We decided it would be cheaper in the long run to get a newer more energy efficient one, because we didn't know what other damage had been done and if fixing everything would just be too expensive and it could quit before everything was fixed.
Sep 13, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Continuing fridge problems
Your freezer is probably not sealing prolly. make sure the door is perfectly lined with the box. You might want to change the defrost timer from the 10hr you have to a 6 hr timer. In high humidity areas too much frost tends to accumulate causing the vents, and the drain line to be clogged. That might be why you have the puddle of water. The ice that is defrosted every 10 hrs runs down that drain line to a pan on top of the compressor, if that line freezes up, all subsequent water from defrost ends up in the refrigerator or freezes in the freezer.
Feb 19, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Freezer okay, fridge warm
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTE18WAA Top Freezer Refrigerator Logo
242 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
