Marzocchi 2008  XC 700 ATA Mountain Bike Fork 100-140mm
Problem for Marzocchi 2008 XC 700 ATA Mountain Bike Fork 100-140mm
Bicycle Fork Installation
By luislain on Oct 29, 2008
Just bought a bicycle fork is there an easy guide how to install it?
Thanks
Luis
Solution #1
posted on Oct 29, 2008
Somewhat Helpful)
Daniel9
Rank: Guru
Rating: 87%, 302 votes
Not so easy but if you follow these step you should be ok:
  • Remove the crown race from your fork. This can be done with a screwdriver and a hammer. Place the end of the screwdriver against the bottom of the crown race and tap lightly. Turn the fork, put the end of the screwdriver on the opposite side of the crown race and tap lightly. Repeat until the crown race comes off. Remember to wear eye protection!
  • Install the crown race on the new fork's crown. This requires a crown race slide punch. Pound the crown race down until it sits flat on the fork crown.
  • Insert the fork into the headtube and measure where you will need to cut the steer tube. Measure twice - you don't want to cut it too short. You can always cut it again or add headset spacers. For a threaded fork, you will need to allow room for the headset and a cable hanger if you plan to use one. For a threadless headset, you want to cut roughly 3mm below the top of the stem, to allow the stem cap to seat properly.
  • Remove the fork from the headtube and clamp it in a fork saw guide. Cut the fork with a hacksaw. Again, make sure not to cut it too short!
  • Use a deburing tool to remove any burs from the inside of the steer tube, and file off any rough edges on the top of the steer tube.
  • Install the star nut if you are using a threadless headset. Tap it gently into the top of the steer tube using a hammer and the star nut installation tool.
  • Insert the fork, install the stem, insert the front wheel, adjust the headset, adjust the front brake, and you're ready to roll!
Good luck
Daniel
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Very Helpful)
AlmostBob
Rank: Guru
Rating: 88%, 513 votes
remove front wheel
undo allen screw or bolt securing headstem to fork
remove headstem and handlebars
undo lock nut & ring retaining bearings, at top of fork tube, do not lose bearings which may be loose.
withdraw fork from fork tube, do not lose upper bearing race
remove lower bearing from old fork
install lower bearing on new fork (I prefer replacing bearings)
remove brake caliper from old fork install on new fork
insert fork in fork tube
install upper bearing (I prefer replacing bearings)
install retaining ring and lock nut on fork tube, adust untill there is no wobble, but free movement, too tight the bearings will collapse too loose the rider will fall off
tighten lock nut
install headstem
tighten headstem allen key - bolt
install front wheel
Was this helpful?
Yes
No
Solution #3
posted on Apr 06, 2009
Not Rated)
mellimargoli
Rank: Apprentice
Rating: 0%, 0 votes
no instructions for my sunlite bike rack which attaches to the back rear wheel of my bike..how do I install it?
Was this helpful?
Yes
No
Popular Solutions for Marzocchi 2008 XC 700 ATA
Questions and Unsolved Problems for Marzocchi 2008 XC 700 ATA
Do you recommend Marzocchi 2008 XC 700 ATA Mountain Bike Fork 100-140mm?
Answer
Answer
On the Schwinn air driver 1100 delux floor pump with guage, how does one get the needle to work... (More)
Answer
what type of cord does the lamar exercise bike cr350 use
Answer
My friend just gave me his blackburn mag trakstand which must be about 10 years old. I need a... (More)
Answer
broke the fill air valve off on the stantion cap can't find anew one,do you know where to find one... (More)
Answer
i have a threadless springer fork with a 1" steering tube, i need that to fit a 1 1/8"... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Bicycle Accessory Experts
Top Bicycle Repairmen
in , FL
(800) 245-3206
DirectBicycleParts.com, a division of Sage Cycles...
Direct Bicycle Parts
(877) 727-8731
BikepartsUSA.com is your online bike store for...
Bike Parts USA
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
