If I press POWER all the lights are ON only for 2 secs and then OFF again
I don't know the cause, but suddenly my laptop died and now when I press POWER all the lights are ON only for 2 secs and then OFF again.
I opened the case and identified a burned voltage regulator near the battery charging socket. I replaced it with an equivalent spare part, but the fault is not removed. I measured all the motherboard test poits, from the adaptor socket down to the battery and it seems it is working OK, especially that when the voltage regulator was burned it was not charging the battery.
Now with the battery in its place, the battery is charging, but the laptop is not starting.
Any helpful ideas?
Thank you in advance !
  • 4 more comments
  • Julian Von Braun
    Julian Von Braun Oct 29, 2008
    I forgot to mention - the laptop is an ASUS A7D
  • jparjun Oct 29, 2008
    Ihave the same problem as mentioned above. My warrenty just got expired 1month back.
  • Julian Von Braun
    All the attached items are removed because the board is under repair (only processor left). Now I extracted the soldered component again (3 legs on one side + ground leg on the other side, aprox 2mm size in length, black colour, similar to a small transistor) and I saw that actually the battery is charged event without it. The main problem now, that is confusing me, is related to where I can find some info about the burned component. The marking is 8C546, no manufacturer logo, nothing else than the code.
    If somebody knows something about this item or an equivalent value for it or can figure out who is the producer, it will be very useful for me.
    Thank you again for the answer, but it would be nice to be so simple :)
  • Julian Von Braun
    The item I am looking for is an SMD component, SOT-223 / SOT-89 type
  • Julian Von Braun
    But can this 8C546 (Motorola) or F28C546 (Fairchild) be the cause of not starting the laptop? Or there is another item that is not working as well?
    Regards
  • Julian Von Braun
    Nothing is pluged in, except the main processor, memory module, battery and AC adapter :)
    The problem as I said is mainly with this component, because I dont't know exactly its function and I can't find its datasheet. I tried at Motorola and Fairchild but unfortunately no result. I also made an alternative research, considerind different spelling line 8C-546 or 8C 546 but after looking in all the results nothing interesting occured.
    I will assume it is an 3 terminal positive voltage regulator and I will try to use an equivalent part and make some measurements on the path between AC adaptor socket and battery socket.
    Also I was thinking that maybe the switch ON/OFF controller that interprets the digital 0 or 1 signal and orders the power on function in you press ON, can be faulty in connexion with an power gate DC-DC but I am not sure.
    First, before going further I must identify this component :)
    Regards
    Genius:
  • 1,605 Answers
I would remove all attached items. memories, hard drive, battery.
unlpug the AC. push and hold the pwer button for 20 sec. (discharge the PC).
plug in the AC and turm it on. (BIOS) only. if that is good, then install other devices.
Posted on Oct 29, 2008
  • 1 more comment
  • Frank
    Frank Oct 29, 2008
    8C546 is porduced by Motorola or equiv.F28C546 by fairchild. this should be an IC chip. I don't remember, its being so long I look at any of the IC. This should be gated IC, in otherword, it is a regulator with a votlage trigger gate.
  • Frank
    Frank Oct 29, 2008
    that might be the problem, I can't really say that is the problem. In general I have see the laptop to tell you what is wrong with unit.
    there are probably few other items that need to be replaced. you can only go one step at a time, and fix one thing at a time. and on, and on....
    I would pull the hard drive out of the laptop and test the unit that way. It is safer, not to kill the hard drive in the porcess.
  • Frank
    Frank Oct 30, 2008
    unfortunately I can get the data sheet. Data sheet is only available to ckt designer. I haven't being in that position over 10 years.
    you can ask any friends who working in electronic or ckt design.
Samsung laptop problems
try cold reset by removing the battery including power adapter then press power button for approx. 20 secs. then plug your power adapter then press power button again. press the numlock/ capslock button if there is response showing that your motherboard isnt dead yet. please check also when fan is running momentarily then suddenly stops then post another question here.
Dec 02, 2013 | Computers & Internet
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
How can i fix error 5200 on my canon pixma ip2770
You can try the following 1. Turn off printer, cable power still plug in,
2. Press Resume Button don't release
3. Press Power Button don't release and than release Resume Buttons
4. Press Resume Button 6X
5. Turn off printer cable power still plug in
6. Turn on printer again, now this printer ready to use.
Or try
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Jul 27, 2011 | Canon Office Equipment & Supplies
My compaq presario v3500 wont turn on again. i was using it, watching movie then it suddenly shutdown. my battery is fully charge and the charger was connected. so i try to turn it on and it wont start....
Remove the Battery and press power on for 1-2 minutes with out AC power .
Please turn on the laptop with only AC POWER (without battery ). Check it. it may turn on your laptop.
If display ok, then insert battery and use it...
Jun 18, 2011 | HP Compaq Presario 2200 Notebook
HI, i have sony vaio laptop. few months ago i face the problem that my computer LCD light. after starting 2 or 3 times it show the screen. it is running every time. i can see dim screen but after 3 or 4...
try to reset it by removing the batery and the power cord an pressing for 30 sec the power button; if is not working maibe you have la faulty LCD inverter and msut be changed.
Apr 29, 2011 | Computers & Internet
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Problem to start after shutdown
first on ur laptop. then after 1-2 sec. press F8 4-5 times ....then u will see a menu..on the top , Safe mode will b written.select it & press enter............thenwait a few min..& go to control panel--system restore...choose a restore point ,,reading the instruction & choose the date or time before the installation of that antivirus..
Jun 01, 2009 | Microsoft Windows XP Professional
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
When I turn on the power to my laptop, tries to turn on but dies
According to me, you should check your power adapter. I think it is not working and is not producing sufficient power supply for your laptop. And due to this, your laptop have not been charging.
Jan 17, 2009 | Intel Motherboard
Tv turns off
Hi there, my husband fix the problem. My small son had changed the settings for the HDMI. My husband switched the tv to DVD mode started a dvd & changed all the settings back. After changing all the settings he also reboothed the setbox machine.
Apr 11, 2008 | Samsung LN-S2651D 26 in. LCD Television
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
