Question about Bravo Sports /Bike Access 1001782 Racing Saddle
How to adjust saddle postions
I would like to know How to adjust saddle positions on my bike.
I have bought a new saddle but it is very straight up and I its very annoying after a few minutes to ride the bike.
How do I adjust it? and what is the best saddle position for long distance?
Thanks
Mike
  • 52 Answers
You can loosen the bolt under the saddle, and adjust it...
for me, the best saddle position for long distance is when it's facing downwards a little bit, so that you can move your legs freely.
Posted on Oct 29, 2008
The saddle is mounted on a seat post, which telescopes into the seat tube of the bicycle frame. The seat tube usually has a gap, which is held together by the seat-post binder bolt. The binder bolt may require a fixed wrench, typically 13 mm or 14 mm; or, it may require an Allen wrench as shown, usually a 5 mm , sometimes a 6 mm; or it may be a quick-release, requiring no tools at all.
To adjust the saddle height, you need to loosen the binder bolt and raise or lower the seat post in the seat tube. It may be necessary to twist it a bit to get it to move. If it is hard to move, you may need to remove it and grease the inside of the seat tube.
The perfect saddle position depends on each person, but I found that for me the best position shoud be pretty close to horizontal. But it depends on you. play with it until you feel most comfortable.Also conftorable position differ between men an women
Good luck
Luis
Can't find a seat that doesn't cause soft tissue tears or bony areas hurt
The body position on a tri bike is cruicial not only for aerodynamics, but for comfort as well. The saddle is the usual "sore" spot for most riders who try to find a more aero tuck. Unfortunately, there is no magic saddle that takes care of everyone's problems. Human physiology differs from person to person and saddles need to fit a wide range of riders. My advice would to try to find a bicycle shop with a saddle rental program, this will allow you to test ride a saddle before purchasing one. Also, do some research on the various saddles out there. I had to try six different saddles before settling on one that is perfect. Here are some links to saddle manufacturers:
Triathlon Bike Saddle For Men amp Women Koobi PRS TRI T1 Welcome Innovative SaddleMaker Products
Mar 27, 2014 | Cycling
How do I find the year my bike was made?
Look on plastic parts like underneath the saddle. Just as with cars, there might be a calendar dial showing the year and an arrow pointing to the month engraved on the plastic. To allow for assembly time, the year might be one later than printed on the plastic. Just keep in mind that plastic components might have been replaced through the life of the bike.
20029802-x4ti4kd13pz3emz5huheloyd-1-0.jpg Attached is the date stamp found on the bottom plastic cover of the saddle on my Dahon bike. I bought the bike brand new in 2015 and according to the stamp the bike was assembled with the saddle of '13. So we can quite accurately say the bike is a '13+1 (2014) model.
Sep 12, 2013 | Gary Fisher Wahoo
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
Mar 04, 2013 | Cannondale Cycling
Why does bike size is important?
It is clear that wearing a shirt two sizes too small would be uncomfortable, and wearing a shirt two sizes too large wouldn't be good either. In the same way, riding a wrong size bike will fit badly and make you uncomfortable, too. There are two main problems, one obvious and one a little more subtle.
The first big problem with a bike that doesn't fit is saddle height. You need the saddle to be just high enough to give your legs the right extension when you pedal. Too low and your legs stay bent too much all the way around; this doesn't use your leg muscles well and you wear out quickly. Too high and you rock back and forth on the saddle as you pedal, very uncomfortable. Either extreme (too high or too low) can also be very hard on your knees.
Saddle height is adjustable, of course, and if the bike frame is at least close to the right size, you'll be able to adjust the saddle to the proper height. If the frame is a lot too small, you can usually overcome this problem by buying a longer seatpost to move the saddle back up to where you want it. (But that causes other problems we'll talk about soon.) If the frame is much too large, you won't be able to drop the seat far enough to be usable, and there is no practical way around that problem.
The saddle on a bike can be adjusted up and down several inches, even as much as a foot if you consider replacing the original seatpost with a longer one. But the handlebars can't be moved nearly as far as saddles can. Most handlebars can be adjusted up and down or forward and back only two inches or so, and even this small change is often a complicated operation of replacing parts, not just loosening a few bolts.
This can lead to all sorts of problems. If the handlebar is too far away from the saddle, you have to bend down further and reach far out to grab the bars. This puts more weight on your back, arms and hands, which is uncomfortable. Having the handlebar too close to the saddle is less of a problem, but in extreme cases it can cause your knees to bump the handlebars when you are standing up to climb a hill. Having the handlebar a lot lower than the saddle is similar to having it too far away-you have to bend far over and reach further to grab the bars, an uncomfortable position. Having the handlebars high up is not a big problem, except that sitting upright slows you down. Your legs aren't as strong when you are sitting up, and that position causes more wind resistance when riding fast or into a wind.
Bike size has a big effect on handlebar position. If the frame is too small, you'll have to push the seat up high to fit your legs. You won't be able to move the handlebar up as much, so it will be a long reach back down to grab the bars, and your back will be quite bent over. If on the other hand the frame is too large, the bars will be up high but might be too far forward (since the frame gets longer as well as taller).
Dec 21, 2010 | Cycling
Need installation instructions for oem vstar 1100 saddlebags and mounts.
Two bolts on the rear fender will need to be removed.
Also remove the passenger Pillion(Seat). Normally one bolt in the back and the pillion slides into the driver seat. Pulling back on the pillion after removal of the hold down bolt usually releases it.
The brackets to hold the saddlebags straight and away from the rear tire/ brake disc. Mounts with shims to the two bolt holes on either side of the bike. (remember those bolts removed earlier?) Center the saddle bags by eye. Sometimes it is best to have someone hold the bike straight and center from the rear. If the bike is on the kick stand, it will not be easy to center the saddle bags.
Next put the passenger pillion back in place.
Check the bracket clearance and make sure no part of the saddle bags are touching any moving part. You can bend the brackets to adjust but usually not necessary. Just be careful with the chrome fender flares.
Those curved chrome rear fender shiny things. :)
You can scratch the paint very easily while working with them.
Use a cloth/towel where you can to prevent marring of the paint.
Really simple to do with minimal tools. Some of the saddle bag bracket kits come with longer bolts. Use them!
My 1100 Vstar I used the twist rods from a set of Shoe Stretchers.
Screwed directly into a kuryakyn foot peg adapter. Black with a triangular tip worked great. Heck of a lot cheaper too!
Nice thing about this arrangement, only had to remove the foot peg bolts. Then the rear passenger seat. Easy to adjust the angle of the bracket by loosening the foot peg either side. Pull up, push down or bend out to get proper position.
Hope this helps!
Sep 12, 2009 | 2005 Yamaha V Star 1100 Classic
Quad fatigue on my road bike what could cause this? I have a new bike and I feel like saddle position is off as far (forward and Back) not the height
Quad fatigue could indicate one of several things:
  • Saddle is too far forward: frequently this strategy is used by triathletes to put the burden of the bike ride on the quads to avoid fatiguing the hamstrings before the running component. This is why Tri bikes have such steep seat tube angles and forward saddle positions
  • Saddle is too low: This causes over-extension of the quads (overbending of the knee) so your initial muscular contraction is higher in tension but lower in value.
Try moving the saddle to a more aft position. This will place more work on your hamstrings and less on the quads, and may create a more balanced workload for the two groups.
Also, if you do not already have them, clipless pedals (I ride Speedplays) will reduce the amount of work done by the quads since you will be able to use more muscle groups during the entire pedalstroke instead of simply mashing the quads on the downstroke.
You might consider seeing a professional bike fitter if you have a new bike and it is giving you problems. You should be able to get a very good bike fitter for about $100. Anyone charging more than that is just trying to use a high price to make their fitting look "better."
Aug 20, 2009 | Quad Cycling
I have today bought a elswick bike and the instruction manual doesn't show how to fix the saddle onto the bike only how to adjust it as the whole bike arrived in kit form, i now have a pile of nuts, bolts,...
One of these two links might help.http://www.youtube.com/watch?v=8t5quD1hFlQ http://bicycletutor.com/new-bike-assembly/. To get an idea of which parts belong to the saddle have a look at another bicycle. The parts are all pretty much the same on generic ones.
Aug 06, 2009 | Cycling
I bought a new seat for my 1996 Fuji Sagres. The old saddle clamp is too narrow for the new seat rails. Where can I buy a different sized saddle clamp that will fit my bike?
take it to a bike shop and get a new seatpost. bike shops
have manuals that they can check to find a seat post that
fits the bike frame and has the proper size rails to fit your
new saddle.
this is a good time to upgrade the seatpost, you can get one
that is lighter and more adjustable that your old one.
Jun 06, 2009 | Cycling
I would like to install saddlebags on my 2005 Springer classic (FLSTSC). I am looking at the 90058-05 saddlebags. Will I need another kit or hardware to install the saddlebags? What is difference between...
We ride the same bike as you and had the saddle bikes fitted when we first bought the bike new. Yes, you will definately need a fitting kit, you do with all the bags, however be very careful about what bags you buy. We have the original 'money bag' shaped bags which were particularly designed for the bike and to match the saddle. The were very expensive and were the biggest waste of money ever! They are so impractical if you have a set of wet gear in each side they are full to bursting and the small opening at the top makes them very awkward. Just last year Harley bought out a new, bigger, set, I don't know what the top opening is like but it has to be better than the ones we have, we are even considering swapping to the new ones as we tour quite a lot.
Hope this helps.
Mar 15, 2009 | 2005 Harley Davidson FLSTSC - FLSTSCI...
Dyna pulling to the right
My Fat Boy pulled to one side, service at dealer first asked me if it started after I added the saddle bags (wind resistance). Turned out the rear alignment was off a little and that now it's riding pretty true. I know from when it was pulling, I could sit a little to one side in the saddle and it would run true, so I suppose it's possible if you're not sitting straight in the saddle, it could pull. Same for load in the saddle bags, more weight on one side could cause it to pull.
Nov 20, 2008 | 2006 Harley Davidson FXDWGI Dyna Wide...
Bravo Sports /Bike Access 1001782 Racing Saddle Logo
612 people viewed this question
Top Bravo Sports Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Bravo Sports Cycling Expert? Answer questions, earn points and help others
