Question about LG Secret ? KF750 Cellular Phone
Video Settings Hi - why can Ii change the settings for video to low light - night and then increase the brightness and I get a perfect pic - why does it return to dark preset when I start to record - manual saya to press save but does not exist!! Thanks
Hey there,
I remember reading about this in my manual
It's under one of the TIP! sections, on page 46 under the 'Video Camera' topic. It says the following;
  • "When you exit the video camera all your settings will return to default, except Video Size and Video Quality. Any non-default setting you require will need to be reset, for example colour tone and white balance. Check them before you shoot your next video."
Same applies to the Camera settings on page 43;
  • "When you exit the camera, all yours settings will return to default, except image size and image quality. Any non-default settings you require will need to be reset, for example, colour tone and ISO, Check them before you take your next photo."
Hope this helps!
- Ness. :3
Posted on Nov 17, 2008
  • Anonymous Nov 17, 2008
    Oh yeah, I forgot to mention my User Guide if for Australian Customers I'm guessing.
    Also I found on the first page into the guide the following;
    • "Some of the contents in this manual may differ from your phone depending on the software of the phone and your service provider."
    That's so retarded.
    - Ness
I chanded the brightness at about 8:30 several day a go. So for the last few nights, at that time the screen gets darker???? But all day long it is fine???
Hi Mary,
Sounds like you've got your TV settings making changes automatically for you based on room lighting. My suggestion would be go to settings, display and then look for anything that may be checked that says auto or programmed and see if that helps.
Jul 29, 2017 | Televison & Video
Low brightness
don't know which kind of camera is yours, is the settings changed ? if you put the filter the brightness will be less, go to the camera menu, scroll to re-set option, execute.
Dec 28, 2015 | Video Cameras
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
The screen on my aspire 5100 is so dark i can hardly see it
hi mary welcome to the forum! 1)you have an Fn key bottom row left, hold down while also pressing right arrow, bottom right. Each press increases brightness. Each press of left arrow decreases brightness. 2)go to the manual of Aspire 5100 that you there is the option "AcerClearVision" in the software "AcerArcade". See manual:"Acer Clear Vision is a video enhancement technology that detects video content and dynamically adjusts the brightness/contrast/saturation levels so that you do not need to change the color settings if the movie you are watching contains scenes that are overly dark or too bright." So you opened "AcerArcade". There you take: "movie or cinema--> settings -->display settings" en there you change in the option 'color profile' 'ClearVision' to 'Original'.
May 21, 2010 | Acer Aspire 5100 Notebook
When i capture a pic in day light than picture will come faded and when i capture in night it comes nice one my camera model is exilim ex z60
make sure the camera's settings are set to normal, since, the lens might be sensitive to daylight. You can actually change this at the settings, and, you said that it works fine at night or at dark areas? Yeah, the lens could be sensitive to bright lights! Simply adjust the sensitivity and you're all set!
Jun 25, 2009 | Casio Exilim EX-Z60 6MP Digital Camera...
When HP laptop is pluged into power source screen goes dim
Right click on the battery icon in the taskbar, go to Power Options or something similiar. Change the plan settings for the power plan you're currently in. Check the brightness ratio for both battery and plugged in mode. This problem might come if you or someone had tinkered with the settings.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Logitech web cam
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Feb 27, 2008 | Logitech Quickcam Chat Webcam
Pic quality
Connection Issues:
Low Light Boost:
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Feb 26, 2008 | Logitech Webcam
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Strange problem in dcr trv 140 sony camcorder.
Did you turn the exposure lock on? That would lock the iris so that it will not adjust for changes in lighting.
Sep 14, 2005 | Sony Handycam DCR-TRV140 Digital Camcorder
LG Secret ? KF750 Cellular Phone Logo
64 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
