Question about Ruud Central System Air Conditioner
I would like to know how to instal the gas valvue
  • The HVAC Guy
    The HVAC Guy May 11, 2010
    What kind of system do you have and what brand is the gas valve. is it a honeywell gas valve? if so just remove the gas pipes from the old valve and install them on the new one and remove wires from the old one and place on the new one
  • 700 Answers
After you do that be sure to check for any gas leaks with a solution of soap and water thick enough so that it will buble and stay on the jonts of pipe.
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Dec 21, 2008
    also you cannot tighten the piping thru the valve.(always have a wrench on the side of the gas valve that you are putting the piping on.
Valvues calibrate
calibrate?
where are you on this car, there are 3000 parts
state a system.
like engine.
the state what part of that?
if it is an engine question , do tell which one you have first
because we can not guess.
here are our, in N.American there are others.
generation 3. engine.
3.5 L V6 210 hp J35a6 OR a7 ENGINE.
3.5 L V6 244 hp (2005)
244 hp (2006) j35A6 OR a7 If touring model.
241 hp (2007-2010)
other counties use.
2.4L 160 PS (118 kW; 158 hp) or 200 PS (147 kW; 197 hp) I4
totally different engines and EFI systems
my guess, is your are reading in some book to adjust
the engine Head valve lash adjusters
if yes, its dead wrong, these engines are HLA
(automatic lash adjusters)
admition,, what is this word.?
Feb 26, 2014 | 2006 Honda Odyssey
Pilot light goes out when you relase the gas controll valvue
your gas heater needs cleaning
you can do it yourself
shut gas off to heater
disconect line going to pilot
and the other end into valve
get a straw and blow into line and where it conects
also use vacuume on the end where pilot flame comes out
clean the end of thermcouple( where flame hits)
put it back together BE SURE CONECTIONS ARE TIGHT
dont want gas leaks
Oct 10, 2013 | Williams (5009622) Ceramic Gas Wall...
Two codes came up on my scanner the egr valve and the O2 sensor i replace those two sensors and it stil does the same. rough idle, poor fuel economy and loss of power. They told me that it could be leaking...
pull you egr valve off and get some brake parts cleaner or carb or throttle body cleaner and clean your valvue also start the car with the valvue off and give it a little gas so you can blow all the stuff out of it then put it back on and erase the codes then drive and see if the check engine light comes back on
Mar 30, 2013 | Cars & Trucks
MY HAIER 1.7 FRIDGE FREEZES ONLY
my trf 285 intergrated fridge freezer has same problem fridge is freezing our food have been informed that a valvue is stuck open the solution
offered was defrost and leave for 2 days i did that it did not work the valvue is not replaceable hope this is some help
Jan 21, 2013 | Haier Refrigerators
I have a gas dryer....gas valvue shows on, but not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 17, 2011 | Dryers
My oven does not heat, but the burners heat i tried put the valvue on, but still the oven not work the glow seen ok they put orange
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 12, 2010 | GE CGS980SS Stainless Steel Gas Kitchen...
When I turn on the steamk valvue the pump turn on for about 30 sec. then shuts off and says ventilate. i just replace the steam valvue today but that was not the problem. can you help?
Check the end of the steam wand for blockage, and or remove the tube feeding the valve and carefully turn machine on and run the steam cycle if no blockage, then remove wand and check for blockage.
May 06, 2010 | Gaggia Titanium Espresso Machine
07 kawasaki kx250f backfires
Hey i have several solutions for you.
The first is have you checked valvue clearence lately, because if the valvue clearence is either to high or to low then it could cause it to back fire. The next solution is repacking your silencer. The next solution is there is two main gaskets in most dirtbikes, one, which is located where the pipe mets the motor. Also the other gasket it where the mid pipe meets the head pipe. The bike fire is usually being caused by extra air. By the way checkin valvue clearence is extremley easy it may sound hard but I do after every ride.
Jun 08, 2009 | 2006 kawasaki KX 250 F
Problem with are 2001 everude boat motor model# 9.9eidevl 45ic
The fuel line priming bulb acts as a check valvue. The bulb is more than likley bad. Cheap to replace.
Apr 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Ruud Central System Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
