Question about Cell Phones
Unusual one - 2 year old grandson dropped mobile behind radiator, only access is from top, any ideas please. Window board two inches from top so cannot get view but can guess where it is by ringing it. Any clever magnet or way to grip?
  • 488 Answers
Thats unusual!! how about a stick with bubblegum or something sticky at the end of it..dunno if it works..
Posted on Oct 29, 2008
Hi year 2000 leak inch wide hose only seen from under drivers dash...all coolant gone .its by the exhaust...any ideas how tp access it or which cool.hose it is?thanx
Sounds like the interior heater hose. This hose is connected to main radiator so you most likely have a low radiator fluid level.
Jan 28, 2016 | Cars & Trucks
Where are the heater hoses under the hood?
I don't have one like yours sitting in front of my house, but here goes.
On most cars, the hoses to the air cleaner are the largest, about 3 inches to 6 inches in diameter.
Next smaller are the radiator hoses, usually there are two, one at the top of the radiator and one at the bottom,
These hoses are usually about 2 inches to 3 inches in diameter. Next smaller are the heater hoses.
There are usually 2.
These are normally from 1 inch to 1& 1/2 inch in diameter, and traditionally are from the engine to the firewall, which is the metal wall in front to the car's interior.
In today's modern cars, it is not unusual that you would have a really hard time finding and seeing the heater hoses, because of their location.
Next smaller are vacuum lines or water hoses for the engine, from 1/2 inch to 3/4 inch diameter.
Most all hoses are black.
If someone can show you all of the parts under the hood and what they do, you can tell the heater hoses by where they go, to and from.
Be blessed.
Feb 14, 2013 | 2000 Kia Sportage
My grandson turned on the parental control and entered a "secret Number" on my 32" CRT TV Model32SC260. When I play the DVD/VCR player there is a big black square in the picture. The child...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Oct 20, 2017 | Sharp 32SC260 32 inch TV
I want 2 use my computor 2 right a personal letter and ime no further on wen i am asking this simpel qwesion ime new on computors very new but instead ov getting a answer i am being asked a pay fof this...
use either word word-pad they are usually found behind the start button it will open up when you click on it don't forget to spell check usually a check mark looking thing and either press print or the left control button on keyboard and p on keyboard it should then print your letter
most public libraries offer beginners classes
and you can always access help in any program by hitting the f-1 key at the top of your keyboard
my 70 year old mother and 90 +year old grandmother took the classes because they had no idea then at most of what i was saying and now they are as proficient as anyone
good luck and please vote
Nov 30, 2010 | Computers & Internet
Top of freezer not freezing and refrigerator not
Dirty coils not likely the problem .
Open the freezer door .( Behind the back panel ( inside the freezer ) is the evaporator fan motor . ) Push in on the freezer door switch , and listen for the fan to come on . Sometimes , the fan will stay on , even if the door is open . Do you hear the fan ? If not , then the main control board , behind the refrig , behind an 8 " X 10 " panel , is probably bad . If you do hear the fan , then you are having a defrost problem . Pull the refrig out and remove the 8 " x 10 " panel .
Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off , due to set temperature reached .
Dec 10, 2009 | GE HSS22GFT Side by Side Refrigerator
Thin Vertical Line top to bottom about 2 inches from the right.
Probable panel is bad. contact mitsubishi maybe they will do somthing for you.
Jun 26, 2009 | Mitsubishi WD62527 62 in. LCD HDTV
2004 Saab 9-3 Window reset
I had the problem of the drivers window rolling back down. This was fixed by removing the electrical connector located behind the door hinge. It looks like an oblong block. You have to prise the top ribbed part right up then pull the block out. Leave out for about 1 minute. Replace it
Dec 30, 2008 | 2004 Saab 9-3
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Accidental Damage !?
dry it completely ... definitely t'l work atleast after two to three dyas ... don ever be in hurry and give it to service center ...
Nov 20, 2007 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
