Delonghi Floor heater
Hi
I have a Delonghi HVR 9033 Retro fan heater and amd having issues with it. When i plug it in the red light on top goes on and the fan will go round for maybe 1 minute before turning off. Regardless of what i then do with then dial it doesn't repsond and the heater fan won't turn and emit any heat. It only responds when i then set the dial back to 0 and the light goes off.
I only bought them about 6 months ago and they were working perfectly but i haven't turned them on in about 4 months.
any help would be greatly appreciated, am not really sur ehow this site works but if you can help thank you!!
    President:
  • 2,712 Answers
Since it is only 6 months old, it is still under warranty. In this case, I think the best thing to do would be to get it serviced/replaced under warranty, and I wouldn't want to touch anything on it to void the warranty. Looks like there is a circuitry issue here.
Posted on Oct 29, 2008
  • 13,433 Answers
As its only 6 months old it should be covered by the warranty, you should be able to get it repaired by your dealer, with no cost to you.
Heater fan motor does not work
If you have a multimeter or 12v-24v light probe attach one lead to body of vehicle (vehicle seat bolt in floor is a good place), in the case of meter, black lead goes here, light probe has alligator clip, then other lead push point into leads on motor red one should be live with ignition on & fan on max, if no power then I'd say check fuses & the fan switch, try removing plug near fan motor & applying 12v directly to the two wires, it should not matter which way you wire this, it will still run if it's going to, but if one is red & the other black, then red is positive.Good luck, these motors very rarely give out, my guess is the switch...
Jan 08, 2013 | 2002 Ford F350 Super Duty DRW Reg. Cab
Heater light turns on but nothing else is working
the power wire leading to the heating element could be broken or burned out or the wire to the fan [ if equipped with one ] could be broken
Feb 20, 2012 | DeLonghi DUH400 Heater
The heater switches off after 2 minutes on all settings
my delonghi heater keeps switching off - really annoying. Seems to come back on again soon after, but Id rather it just stay on! Any ideas?
Aug 30, 2011 | DeLonghi Retro Fan Heater
Delonghi heater mg15t sprung a leak oil all over the floor, pulled plug and am a very handy person. use to work on cars etc advise. what could be problem
I suspect it may have over heated and sprung a leak or burst a seam. If that is the case, there's more to it than just repairing the leak. The reason it overheated is the main issue and is it worth repairing or can it be safely repaired? Too many variables here.
Mar 02, 2011 | DeLonghi Heating & Cooling
What does the asterik with the tear drop on the middle control mean on DeLonghi AR690 Retro Toaster Oven?
Here is contact info for DeLonghi if no one else can answer you.
EMAIL
Our consumer service representatives strive to respond to all e-mail inquiries within 24 hours of receipt. help@delonghi-csservice.com PHONE
To speak directly with a consumer service representative, please call 1-866-Latte- Best (1-866-528-8323). Representatives are available 8:30 am - 5:00 pm (EST) Monday through Friday.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 18, 2011 | DeLonghi AR690 Retro 1500 Watts Toaster...
Oven just stopped working
1-usually it easy proplem
2- check your electricity voltage by testsrowdriver or another good device like radiocasset or voltmeter if you can
May 31, 2009 | DeLonghi XR450 Retro Toaster Oven with...
Over Heating
Heater core and radiator are separate issues. But, both may have the same problem. The best non-commercial way I have found to remove internal obstructions from either is to use a household calcium and rust remover (like CLR)...On heater cores, remove both hoses and fill the core with product, then let it stand for a couple of hours. then drain and backflush.
On engine radiator, remove it, plug the lower hose connection and do the same...fill with product, let stand then backflush, then turn radiator upside down & repeat in opposite direction. The reason standard water flush often does not work is that water simply goes around the plugged area and does not remove anything except for minor debris which sometimes can actually plug other passageways and make the condition worse.
Back to the heater. It's possible that a blend door is not operating and therefore not allowing hot air to enter the heater box...check this as well.
Definitely make sure that fan is coming on and that the thermostat is actually working (I don't trust anything new just because it's new) Also check sensor & relay for fan.
Likely information "overload" but I hope something here helps!
May 15, 2009 | 1998 BMW M3
Won't heat
Try calling delonghi america at 1800 322 3848
Dec 14, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
