Question about Panasonic PT-53WX42 53" Rear Projection Television
Blue looks like it is caved in to the center
I got some pic's below. This is what started to happen to my projection tv few days ago.
First I thought it was a lose cable or something to do with the connection.
every input on the tv have the same problem, looks like blue is caved towards the center. even when you first turn on the tv the channel
on the upper left have colors shifted. so I'm sure it's something to do with the tv, not the cable box. blue is so far off even with color calibration I can't move it that much.
Maybe the projector light at the back is dying or some thing. This tv is 6 years old. How long do prejector light should last I don't know. any input would be helpful...
  • nurik_nurik Nov 15, 2008
    Just fixed the problem yesterday.
    Replaced the convergence correction IC's
  • 934 Answers
Need to replace the convergence amps and test / replace one or more of the 2.2 ohm resistors in the yoke return out in front of the amps.
That unit uses two stk392-110 Sanyo amps, buy originals not the chineese knockoffs. Acme Sales in Florida can sell youthe amps and resistors.
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
Posted on Nov 15, 2008
I have a RCA Hd52w59 television that has a blurry red green blue colors on screen and the pics looked like they are caved in .any help ?
RED BLUE and Green are the component colors. If you are using component cables, which most likely you are, check to see if the Green has come unplugged. Try switching the cabls to a different input. Actually, if you get the same problem on another input that say....your DVD player is hooked to, you have a bad tv. If not, try to isolate it to the simplest thing first e.g. cables, input source, etc. Please don't forget to rate this solution for me.
Jan 21, 2011 | RCA HD52W59 HDTV Projection Television
I have a large sony hd read projection / a few days ago - i started getting faint green lines that are arched - higher in the center - symmetrical, an about 1.5 inches apart - a few times , the tv has...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Jan 09, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Blue Haze in middle of screen progressively getting larger
This one is easy. WHen this happened to me, I simply called GE extended warranty service up and bought an extended warranty. I waited 30 days and called them up with my problem. A repair man showed up a few days later with the 1200 dollar light engine and installed it and left. Then I called GE up and cancelled the warranty. Total cost?: 48 bucks
May 30, 2009 | Hitachi 50V720 Television
Blue dots in center screen after installation of new home theater system
Looks like you may had some unshielded speakers near the back of the unit the caused the color to bleed or fade this is perm damage to one of the guns that shoot the pic to the mirror. There is a fix for it but it may be a costly one.
Apr 22, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Blue cloud
Problem fixed by reading other post with same problem. Unfortunately Sony is not going to fix this problem.
Apr 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue tint on bottom of screen
I have the same KDF60XS955 sony and have the same problem. I called sony customer support and was told there was a recall on the optical block for this tv. But the recall ended in Dec. of 2008. I was upset that they did not call or send out a notice to me. They should of had my information because I had a different issue that they sent someone out to fix a few years ago. They said it was an expensive fix, like over 1000 dollars. Instead of fixing it they offered me a deal on a smaller tv, a 52 inch sony. I could buy that one at a discount which is about 1100 dollars. I told them that I thought that was the worst deal I have ever heard of. Why would I spend about 4000 dollars for a tv 4 years ago only to be told that I could buy a smaller one today for 1100 dollars more. I said if I bought that 52 inch tv today, what would happen 4 years from today, am I going to be offered an even smaller one for more money again? I thought I was buying a top of the line tv back then, I only wished it would have lasted longer than this. Not happy!
Mar 16, 2009 | Sony KP-46WT500 46" Rear Projection...
Power outtage has my dlp hdtv actin weird
unhook everything from the tv and wait for a few minutes, go into the factory mode and do a reset, factory mode code is , mute-182-power
Jun 24, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Mar 21, 2008 | Samsung HL-R6167W 61" HDTV
Panasonic PT-53WX42 53" Rear Projection Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
