I have a freecom external hard drive which has been working fine until last night when it has started clicking and not being recognised at all by my laptop. I have all my pictures and videos on this hard drive and I can't get to them! Help
  • froggeja Dec 07, 2008
    I have exactly the same problem. Have you managed to solve this yet?
    I have exactly the same problem. All photos and 10 years worth of work documents. Not backed up.
    Did you manage to fix this?
    Thanks
    Jason
  • 68 Answers
oh dear it sounds like the hard drive may of failed.
The clicking is generally the head hitting the end stop.
In the past I have managed to recover drives just long enough by sticking them in the freezer for 24 hours, taking it out and hooking it back up an hour or so later.
Or the drop fix occasionaly works, drop the disk in a flat surface from a couple of feet high.
If you try either of these its entirely at your own risk but failing sending it off to a data recovery house theres not really much you can do I am afraid.
Sorry I couldnt of been more help
Regards
Nick
Posted on Oct 29, 2008
How do I backup files to my Freecom external hard drive XS 3.5 ?? Ive installed it but cannot workout how to use it !! there are no manuals !!
you can open Computer on your screen and then there is C: drive and Freecom labeled to it. Open first the C drive, click Ctrl + A to highlight everything. Then click Ctrl + C. Then go back to Computer and click Freecom. Then click Ctrl + V. All the files will be transferred to Freecom. Then you may proceed for your next step. That is how you back up files.
Aug 10, 2010 | Computers & Internet
Laptop not recognising
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
May 18, 2009 | Freecom MediaPlayer-35 (80 GB) Digital...
My freecom external hard drive is not being recognised by my PC
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
May 07, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Freecom 500gb external hard drive not working
Try another computer, likely if it was plugged in though and was not protected with a surge protector its gone. Their are expensive services that might be able to retrieve it though, but that could cost hundreds to thousands of dollars.
Without being physically at the pc it's still going to very hard to diagnose it, try to find a family friend or someone who is well versed with computers to have a look. Or you might try a local repair shop.
Apr 17, 2009 | Freecom Computers & Internet
Freecom harddrive beeping
Had the same problem. Just checked with their tech support: regular beeping can mean that there is not enough power going through the unit. I tried another USB port on the back of the computer (ie one connected directly to MB) and it worked fine.
Mar 30, 2009 | Computers & Internet
Freecom external hard drive classic 2.5
Have a look here>
http://www.freecom.com/ecDrivers.asp
I can't see any Mac drivers for the drive...
I found this page>
http://freecom-usb-osx.sourceforge.net/
You might be able to get some help here...
Jan 03, 2009 | Freecom (24358) 160 GB Network Hard Drive
Seagate Hard drive
There is a problem with EXTERNAL.Hdd is fine just buy new external and it will work fine again;)
Jan 02, 2008 | Computers & Internet
Freecom 400gb Drive
Have you tried to connect those drive individually and checked if they get detected when stand-alone? If they get detected stand-alone, install the Freedom software happen. Cheers
May 23, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
