Question about Microsoft Windows XP Media Center Edition 2005 for PC
Wuauclt.exe keeps shutting down and the only way to clear the screen is to reboot. What is this program and why does it shut down? I'm running Windows XP Media Center 2005.
  • 76 Answers
Running avast computer shuts down showing system recover from serious error.
Did you have Avast installed previusly or was it the first run?
In any case, try to do a System Restore to a point previous to this strange behaviour.
If you can't localise it in your Programs (Start) find exe file in
C:\Windows\System32\restore\rstrui.exe
Presume your system disk is C: and system forlder is windows. Use the proper one if it's different
Aug 01, 2015 | Microsoft Windows XP Professional
When i want to shut down my laptop it wont shut down. it keeps saying shutting down. I have to turn of my battary and put it back. this is not the best solution iv checked all my program files and all are...
Start-Run - MSCONFIG
unselect all the startup items and reboot. Then check if it shuts down properly (which it should now) - then go through each startup item with a reboot inbetween to see which is the troublesome one.
Bear in mind you may disable your antivirus program doing this, so make sure this one is reselected after your troubleshooting.
Aug 10, 2013 | eMachines Computers & Internet
16 bit MS-DOS Subsystem C:\ WINDOWS\system 32\wuauclt.exe The NTVDM CPU has encountered an illegal instruction. CS:Oe57 IP:fff8 OP:fe ff 57 Oe fe Choose 'close' to terminate the application repeated...
wuauclt.exe stays resident in the background and checks Microsoft website for the operating system updates.
Originally, wuauclt.exe is a legitimate system process that is located at C:\Windows\System32, but there are cases when wuauclt.exe is actually a disguised virus, Trojan or a worm.
If you find wuauclt.exe stored anywhere different from its original location, you should get really suspicious and scan your system for possible threats.
Search for the file and see if you have this in more than one location.
Your system might be infected.
Mar 06, 2011 | Toshiba Core 2 Duo Laptop Computer PC...
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
When i turn on my computer i see windows updates 3 of 3 0% complete do not turn of your computer, then the computer shuts it's self dowm and restarts and the same screen comes up. what can i do?
press alt+ctrl+delete
go to process tab...
find any process name wuauclt.exe
end this process..
go to run ...type services.msc
double click automatic updates
click stop > ok >
then again.....double click it....click disabled....
Dec 19, 2009 | Acer Aspire 3690-2196 Notebook
Won't shut down completely
If shutting down XP takes what seems to be an inordinate amount of time, here are a couple of steps you can take to speed up the shutdown process:
  • Don't have XP clear your paging file at shutdown. For security reasons, you can have XP clear your paging file (pagefile.sys) of its contents whenever you shut down. Your paging file is used to store temporary files and data, but when your system shuts down, information stays in the file. Some people prefer to have the paging file cleared at shutdown because sensitive information such as unencrypted passwords sometimes ends up in the file. However, clearing the paging file can slow shutdown times significantly, so if extreme security isn't a high priority, you might not want to clear it. To shut down XP without clearing your paging file, run the Registry Editor (click Start > Run, then type regedit in the Run box) and go to:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
  • Change the value of ClearPageFileAtShutdown to 0. Close the Registry, and restart your computer. Whenever you turn off XP from now on, the paging file won't be cleared, and you should be able to shut down more quickly.
    Note: Please be careful when editing the Registry; you can do a lot of damage here. Don't change or delete anything unless you know exactly what it is.
Apr 13, 2009 | Computers & Internet
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Jan 10, 2009 | E-Machines T2742 PC Desktop
Roxio media manager install
If you go to start menu and run, type in msconfig.
Go to the startup tab and uncheck the items you don't want loading up - roxwatch9.exe is one (whether or not there's a separate entry for media manager I can't recall).
Reboot, tell the nag screen please go away and don't bother me again.
Apr 24, 2008 | Dell Inspiron E1505 Notebook
Mio digi walker 220
application MioUtility,exe has performed an illegal operation and will be shut down. if the problem persists, contact the program vendor
program:MioUtility,exe
Exception:0xC000000D
Address:8C06DF8C
Mar 20, 2008 | GPS
Microsoft Windows XP Media Center Edition 2005 for PC Logo
141 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
