SanDisk Sansa e250 MP3 Player
Problem for SanDisk Sansa e250 MP3 Player
Freezing Up
By Jodi on Sep 06, 2006
I was transferring songs on to it when it froze up. I can not turn it off. What do I do??????
Same Problem
Mar 23, 2008
-   I plugged my Sansa into my computer it didn't read it then when i went to settings while it was plugged in. The screen just white and it won';t turn off!!-   Twizzy
Mar 17, 2008
-   HOW TO FIX SanDisk Sansa e250 REFRESH DATABASE!!!! If this occurs you have downloaded a song that locks up the Sansa, so remove that song or add a song at a time then after each disconnect and it will refresh until you come to the song that creates the problem - solution is simple, don't add that song. No need to Format or Reset to Factory settings ------ this works everytime!-   metaknight
Feb 27, 2008
-   When I connect my sansa to the computer a box used to come up that said what do u want windows to do
Play in windows media player
open folder
no action
But now that i connect it the box doesn't pop up. I click my computer, I click on the sansa icon which changed for some reason, click on music, and it freezes! I disconect the mp3 player and its fine. I can still hear the songs on the mp3 player but it wont open the folder in which the music is in. It only has the folder with pictures and videos, but no music.-   mexilatina
Feb 16, 2008
  • Its usually when i go to see my pictures on my Sansa then it starts to freez and i cant turn it off and when i plug it into my computer the icon will come up and ill press cancel and go the (Start) then my computer and the icon isnt in there all the time some times it is sometimes it isnt and i dont know what to do!!! and i just got it please help me i really wanna keep it but it freezes on me!
-   Mountain Jew
Nov 25, 2007
-   My Zen V is locked up in the docked mode . I cannot do anything with it and my laptop does not recognize the Zen anymore-   Guest
Best Solution
posted on Jan 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Reset the device by using a paperclip (insert it in the little hole next to the "Hold" button).
Solution #2
posted on Jan 06, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Did you try holding the on/off button down for 15 sec. to shut it off?
Also, I was just on the phone to Sansa support and she said that the locking up problem is sometimes associated with removing preloaded songs. She suggested that I reformat the drive by connecting in MSC USB mode. (Change in settings on your mp3 player) Connect the mp3 player to the computer and go to MyComputer (usually on the desktop of windows XP) Right click on Sansa260 drive and move down to format. It takes a few minutes and I did disconnect while it still said writing on the mp3 screen. All files were gone and I reload. It seems to be working fine now.
Solution #3
posted on Dec 05, 2006
Very Helpful)
craigallan
Rank: Apprentice
Rating: 100%, 17 votes
Hi, what you need to do if it freezes again is hold down the power button and the volume up button, this resets it. it is a common fault and happens to mine all the time.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Feb 22, 2007
Very Helpful)
giggsy
Rank: Apprentice
Rating: 100%, 2 votes
Hey I know a better solution. Near the usb connector on your mp3 player there is a small hole. It is actually a reset button. Press it and it will restart without loosing any data or damaging the battery.
your's
patrick
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
Very Helpful)
Lady Lace
Rank: Apprentice
Rating: 100%, 1 votes
try resetting it by holding the menu button and the middle button.
Was this helpful?
Yes
No
Solution #6
posted on Jan 18, 2007
Very Helpful)
pilsbury
Rank: Apprentice
ive had problems with that to go to the bottom of the mp3 were the charger import is theres a little hole take a paper clip and stick it in it is a reset button
Was this helpful?
Yes
No
Solution #7
posted on Jan 16, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ok didnt reallyget why the last person said wait for the batteries to die b/c u can just take it out. DUH! anyway thats what i did and it worked fine.
Solution #8
posted on Jan 15, 2007
Very Helpful)
rzison
Rank: Apprentice
Rating: 100%, 34 votes
Hold the power button for 15 seconds or so. This resets the power and doesn't require you to remove the battery.
Was this helpful?
Yes
No
Solution #9
posted on Jan 12, 2007
Very Helpful)
HELLOTRIPP
Rank: Apprentice
Get something small && sharp, && at the bottom next to the USB plug in, theres a RESET button.
Was this helpful?
Yes
No
Solution #10
Very Helpful)
Holl
Rank: Apprentice
Rating: 100%, 3 votes
This happened to me once, and I tried out the solution above. However, I figured out that if your screen freezes up and won't turn off, all you need to do is simply switch the BATTERY SWITCH from on to off. You know that switch, right? Where when turned off, you can only use the gigabeat by plugging it in? Well, just turn that off, then turn it back on, and recharge it if your battery is low. It worked for me, so it should probably work for anyone else.
Was this helpful?
Yes
No
Solution #11
posted on Dec 10, 2006
Very Helpful)
lil s
Rank: Apprentice
get a neddlel and push the reset hole on the side. trust me it works!
Was this helpful?
Yes
No
Solution #12
posted on Nov 15, 2006
Very Helpful)
karla
Rank: Apprentice
Rating: 99%, 48 votes
I had the same problem, if you hold the menu/power button down for 15 to 20 seconds... it will turn off... then you can turn it back on and everything should be back to normal.
Was this helpful?
Yes
No
Solution #13
posted on Feb 21, 2007
Very Helpful)
vic123
Rank: Apprentice
Rating: 93%, 29 votes
dsfdfdsf
Comments:
Feb 21, 2007
- hold the menu button for 20-40 seconds.
Was this helpful?
Yes
No
Solution #14
Very Helpful)
Gsxr_505
Rank: Apprentice
Rating: 95%, 4 votes
i held my power button for like a minute and it turned off and on it seemed to fix the problem
Was this helpful?
Yes
No
Solution #15
posted on Jan 02, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have a better solution:
1) Unscrew the screws on the back
2) Take out the battery and wait a few seconds
3) Put back the battery
4) Screw back on the screws
Do this and it should work. I just finished fixing this problem!
Solution #16
posted on Mar 03, 2007
Helpful)
whats a mac
Rank: Apprentice
Rating: 90%, 7 votes
Instead of sitting there waiting for the battery to die, simply toggle the hold button on then off. Then press the center button and the Menu button at the SAME time, and hold it for 6-10 seconds. You may have to do this a few times before it actually works.
This resets the pod, but it will not cause you to lose your music.
N
Was this helpful?
Yes
No
Solution #17
posted on Jan 11, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you don't want to wait 20 hours for the battery to go flat you should simply reset the unit.
To do this get a paperclip, bend it a bit and insert the end into the small hole between the volume wheel and the headphone socket. With a bit og gently feeling around you will find the reset button which you should press. The unit will reset into an off state. Turn it back on and use it.
Solution #18
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
remove the 4 screws from the back and take out the battery wait 10 seconds and replace it wait till the player refreshes and your good
Solution #19
Helpful)
BarbaraJae
Rank: Apprentice
Rating: 85%, 6 votes
Rather than having to wait for the battery to run out, you can just reset the MP3 player. There is a small hole on the bottom right next to the place for the USB cable. Just insert the tip of a pen or a safety pin and hold it in for 5 seconds. The MP3 player will turn off. When you turn it back on, you may have to re-sync your songs.
Was this helpful?
Yes
No
Solution #20
posted on Jan 08, 2007
Somewhat Helpful)
sammy_joe
Rank: Apprentice
Rating: 80%, 2 votes
take the battery out the back then put it back in
Was this helpful?
Yes
No
Solution #21
posted on Oct 30, 2006
Somewhat Helpful)
Alex Ultra
Rank: Apprentice
Rating: 92%, 68 votes
Okay, my sugggestion is basically what Big And Rich said, except the m200 line uses AAA batteries that you can just pull out and put back in. But I think the big issue is the freezing part, not where it's frozen and you can't turn it off.
I've read that some people have noticed that their Sansa, and sometimes even their computer would lock up or freeze when they try to transfer a large amount of files at once, and that they get around this by only transferring just a few files at a time; if you're going to do this, it's been suggested that doing it through Media Player's 'Synch' feature is something of a waste of time, and instead the best way is to let the Synch create the folders where the music files go, then use drag-and-drop with Windows Explorer. (Basically go in the drive from explorer, find where WMP dropped the files it managed to drop, then copy over the other files you want from where they are in your Music folder, or wherever the files are.)
Apparently the bug they were talking about doesn't happen when used over a full USB 2.0 High Speed setup, but I think that computer power and maybe a few other things may contribute, such as low battery for the Sansa, corrupted MP3 files, trying to transfer an incompatable format, ect... I don't know exactly how much use any of this might be, but I thought I'd try and give you something useful. ^_^;
Was this helpful?
Yes
No
Solution #22
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sandisk has problems. Remove battery to turn off or switch to the LOCK mode. However, when you turn it back on you will probably be stuck on the "Initialization" screen also to refered to as the "Paperweight Mode". Cannot be repaired.
Solution #23
posted on Sep 24, 2006
Somewhat Helpful)
Big and Rich
Rank: Apprentice
Rating: 73%, 85 votes
Ok what any person will do is just wait for it to completly just waste all the battery then when thats done you connect it agin and recharge and thats it eventually this will be the first and only.
Your´s´
Piterpunk
Was this helpful?
Yes
No
Solution #24
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Take the battery out then put it back in, and restart it....
Solution #25
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Had the same problem. Nothing mentioned here fixed it so I updated the firmware and all sweet. No more problems.
Solution #26
posted on Nov 14, 2006
Somewhat Helpful)
yellojello
Rank: Apprentice
Rating: 70%, 1 votes
remove the battery and send a complaint letter to the manufacturer as well as a copy of the reciept if available. ssend the product back once the company gives the all go.
Was this helpful?
Yes
No
Solution #27
posted on Sep 25, 2006
Somewhat Helpful)
cuezer
Rank: Apprentice
Rating: 70%, 2 votes
Press the little gray reset button next to the USB port on your player.
Was this helpful?
Yes
No
Solution #28
posted on May 30, 2007
Not Rated)
BenjaminaBOY
Rank: Master
Rating: 68%, 19 votes
Take the Batteries out of it.
Comments:
May 30, 2007
- Also if you just leave it on it can hurt the screen! So BE Very CAREFUL!!
Was this helpful?
Yes
No
Solution #29
posted on Mar 09, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
press the restart button!
Solution #30
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Call Sandisk support. M240s are freezing up. Return, no repair.
Solution #31
posted on Mar 07, 2007
Not Rated)
dacarras
Rank: Apprentice
Rating: 0%, 0 votes
I try solution 1 and 2, and the problem persist. The reset button is all in all a very good idea to keep on track your mp3 player; solution 2 also resolve parttially de problem: the mp3 player could reproduce mp3 so i can listen my music; but i could'nt transfer any new mp3.
I decide to upgrade the firmware to ums v1.171
Now it's fully functional.
Comments:
Apr 29, 2007
- I think i have a solution to the freezen problem.
My pc has 3 USB ports that were not so direct to motherboard. It was on those ports that i have theis problem
Adittionally my pc has 6 usb ports, that were really closer to the motherboard, specifically atach to it. I think th efreezing issue is one of electrical resistance, due to serial connections (cable, port, cable).
I have been connecting my t20 to the back ports on my pc, that are attached to the motherboard, adn the problem no longer shows.
PS: excuse my poor english.
Was this helpful?
Yes
No
Solution #32
posted on Mar 02, 2007
Not Rated)
redhot
Rank: Apprentice
Rating: 0%, 0 votes
Toggle d power/hold and hold the power button on power on until the welcome screen comes on. this will put the player on recovery mode. Select reboot from recovery mode
Was this helpful?
Yes
No
Solution #33
posted on Mar 01, 2007
Not Rated)
LaSuperChica
Rank: Apprentice
Rating: 0%, 0 votes
Press the menu and the circular button which is at the center at the same time for 10 seconds and it will reset..
breNda!
Was this helpful?
Yes
No
Solution #34
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This happened to me once, i removed the battery for about 10 seconds and then put it back in. It was then ok and hasn't happened since.
Solution #35
posted on Feb 28, 2007
Not Rated)
rajathegod
Rank: Apprentice
Rating: 70%, 3 votes
manually try to switch OFF and switch ON the player. if it doesn't work then try out the reset button. refer manual
Was this helpful?
Yes
No
Solution #36
posted on Feb 27, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Take a paper clip and reset in on the bottom of the payer.
Solution #37
posted on Feb 23, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Or rather than wait reset it by using a sharp object (end of a paperclip) to hit the 'reset' at the bottom of the machine.
Solution #38
posted on Feb 20, 2007
Not Rated)
Shockie
Rank: Guide
Rating: 90%, 29 votes
There's a little area at the bottom that says, reset, you take a thumbtack, and just pop it in! It will be back to working condition without losing files with no problems!
Was this helpful?
Yes
No
Solution #39
posted on Feb 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
That happened to me.
solution:
plug it back in to the USB and press the back button when it says conecting then take it out
Solution #40
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
solution:
Solution #41
Not Rated)
synchrogrl
Rank: Apprentice
Rating: 0%, 0 votes
take the battery out of the back and place it back in when the screen is clear
Was this helpful?
Yes
No
Solution #42
Not Rated)
rjslmr
Rank: Apprentice
Rating: 95%, 14 votes
there is a reset button on the bottom of the unit stick a paper clip inside the small hole
Was this helpful?
Yes
No
Solution #43
Not Rated)
Poopoohead
Rank: Apprentice
I've been through that before. I just pressed the restart button at the bottom. When I turned it back on (thinking now I have to download all the songs again) all the songs and pictures were still there!!
Was this helpful?
Yes
No
Solution #44
posted on Jan 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem except it wouldn't turn on after I transferred some songs. The reset button was the fix. I would have never known!
Solution #45
Not Rated)
GzUp
Rank: Apprentice
Rating: 0%, 0 votes
Use a sharp needle to press into the reset button behind the mp3 playa.
Was this helpful?
Yes
No
Solution #46
posted on Jan 13, 2007
Not Rated)
brandonl
Rank: Apprentice
Rating: 0%, 0 votes
for a quicker solution try unscrewing the battery pack and reconnect the wire, im waiting on mine at the moment to die because i have no screwdrivers small enough.
best of luck,
brandonl
Was this helpful?
Yes
No
Solution #47
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Toggle with the Hod switch ( flick it back and forth about 45 times) then press Menu then the center button.
Solution #48
Not Rated)
gilloz
Rank: Guide
Rating: 84%, 8 votes
Open your Task Manager window and see if it is "Not Responding". End the process and wait.
Was this helpful?
Yes
No
Solution #49
Not Rated)
kenbo11
Rank: Apprentice
Rating: 90%, 1 votes
Did you try the reset button on the bottom of the player?
Was this helpful?
Yes
No
Solution #50
Not Rated)
Wild2DMaxx
Rank: Wiz  SanDisk Expert
Rating: 90%, 136 votes
the problem with what your saying, Big and Rich, no offense, but after using one of these mp3 playerS for a year, you will know that it doesn't have a rechargeable lithium ion battery...it takes 1AAA battery for up to 17 hours, I believe it is, so you need to reformat the Mp3 player.
Was this helpful?
Yes
No
Solution #51
posted on Dec 25, 2006
Not Rated)
Hamtari
Rank: Apprentice
Rating: 68%, 6 votes
Hi
I just have this problem too. It also occured too me before, but the first time I let them(from where I bought)fix it. This last time the garanty was over. You plug the mp3 player in to your computer and format it, if u have some mp3 files on it, do copy them to your harddisk. Then u download the firmware of samsungs site of this mp3 player. You follow the instructions and ur mp3 player is fixed. I have put this message earlier in this problem.
Greets Hamtari
Was this helpful?
Yes
No
Solution #52
posted on Dec 07, 2006
Not Rated)
risvanah
Rank: Apprentice
Rating: 0%, 0 votes
risva... indicated that his solution for
Flamino 1000 MP3... Problem
is valid for all SanDisk MP3 and...
For Flamino 512mb mp3 player, there would be a small hole right near to the head phone socket. It is a very small hole tht resembles the hole in a CD player tht s used to eject a CD incase if it get stuck. That small hole has to be pricked slightly so tht it gets restarted.
A General Info : Any Digital or Electronic device that has no option for the user to interact with the battery( molded battery devices..) will have a small hole for the system to restart. Guy's juzz check this out !
urs Mr. X
Was this helpful?
Yes
No
Solution #53
posted on Nov 02, 2006
Not Rated)
Mingo
Rank: Apprentice
Rating: 0%, 0 votes
This has happened to me also. I can't remember how i found out, but it can be turned off at any time by pressing and holding the stop button continuously for 10 seconds.
Was this helpful?
Yes
No
Solution #54
posted on Oct 22, 2006
Not Rated)
alcalde
Rank: Apprentice
Rating: 0%, 0 votes
I have a WaveX Digital WV-830C, which identifies itself as an SR-M800F when connected to the PC via USB, so apparently it's a rebranded Safa (looks identical to Safa pics I've seen too, other than case color). On the side of the player without the record & hold buttons should be a tiny little hole. If you stick a pin or better yet an unbent paper clip into this hole, you will be able to press a reset button that should reset the device if it ever locks up.
Was this helpful?
Yes
No
Solution #55
posted on Oct 18, 2006
Not Rated)
SoCol
Rank: Apprentice
Rating: 0%, 0 votes
Hi, I had the same problems with mine. I called ipod tech support and they walked me through a few steps and we learned that it was the virus protection software that is freezing the computer, I had it go to a blue screen/safe mode all the time until I was able to "back door" the anti-virus software. So check your anti-virus protection, mine is McAffee - the ipod folks told me that they are getting a large number of calls re: this kind of problem.
Hope this helps.
Was this helpful?
Yes
No
Solution #56
posted on Sep 27, 2006
Not Rated)
jimbow
Rank: Apprentice
You can also open the battery compartment and disconnect the battery, wait a few minutes and reconnect the battery.
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa e250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa e250 MP3 Player
Do you recommend SanDisk Sansa e250 MP3 Player?
Answer
Answer
I can't turn the player on.the circular ring is lit,but no responce.it is sandisk sansa e250 series
Answer
I can not change my playlist on my sansa 250e error message
Answer
how do i load media. it will load but when i try to play it says unsupported media format
Answer
My sansa MP3 player is stuck - I charged the battery thru my computer and when I tried to turn it... (More)
Answer
screen out of focus how do i refocus
7 Other Users Have The Same Problem - Continued
Comment by geekfreak, posted on Nov 05, 2007
RCA Lyra Th1032 MP3 Player
Same problem: It displays RCA and never changes. I have tried to reformat but windows is unable to do that. Does anybody know how to factory reset this little beast?
Comment by bobbyhead, posted on Nov 03, 2007
i was clicking the centre button of my friends sisters 4gb 2nd gen Ipod nano continuously when it completely froze. i tried charging it and pressing all the buttons. Please help she doesn't know about it HELP!!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For SanDisk Sansa e250 MP3 Player:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 780
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
