Question about Panasonic Lumix DMC-FX9 Digital Camera
Blurry downloads Panasonic lumix DMC fc18
Hi. Pix look great in the camera, but when downloaded on any of my 3 computers are VERY BLURRY. Thanks in advance for any help
5 Suggested Answers
SOURCE: lumix pictures blurry
you might have accidently slowed your shutter speed in the settings
Posted on Dec 18, 2007
  • 172 Answers
SOURCE: panasonic lumix dmc-tz3
The TZ series is not known for good indoor pictures. T Z is short fot Travel Zoom. The is great for outdoor pictures and long distance shots.
Indoors, be sure you use flash and your subject is within 8 feet so flash light can reach them. Let the camera select the proper settings using the Intelligent ISO setting.. Or set it to Night slow shutter speed) while holding the camera, and subject very still for 3 seconds after shutter press, and with Image Stabilization on.
Also, don't forget if you are viewing the pics on your big screen PC, then the pics will always look worse than they will either on your Camera screen professionally printed pix fo 5x7, which will likely be fine to acceptable. If you get up to 9x10 printed sizes, then you will likely see what you would see on a large PC screen....not very good.
There is a chance you have a bad camera. If it is under warranty, take it to a panasonic repair center locally. I am afraid if you send it off to a depot, they may charge you while declaring nothing is wrong with it.
Posted on Feb 27, 2009
SOURCE: Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Posted on Dec 31, 2009
  • 11967 Answers
SOURCE: Can I adjust the shutter speed on my Panasonic
You're asking a lot of a point-and -shoot camera. For the waterfall, set your ISO for the lowest setting and put your camera on a tripod. Shoot when the day is cloudy. For a shallow depth of field, the best you can do is use the zoom at maximum and stand farther back. Sounds to me like you're ready to step up to a DSLR camera!
Posted on Apr 14, 2010
  • 13 Answers
SOURCE: My Panasonic Lumix® DMC-ZS3 will not focus
Try checking your settings or menu for a vibration sensor or changing the focus. You might also be using the wrong setting, like indoor, when you're at the beach. You can also change the quality of the pictures and if you are taking still photography or movement.
Posted on May 31, 2010
Panasonic Lumix DMC-ZS3 When I focus the camera
hi
you have a problem wtih the photo shutter of camera
you must replace it
the cost of it is to high you better replace the camera
Jan 09, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
BLUR PICTURES
Memory cards don't cause blurry pics. Is your lens clean? Is the lens extending properly?
Jun 23, 2010 | Panasonic Lumix DMC-FX50 Digital Camera
Apr 07, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic lumix dmc-tz3
Nov 19, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix DMC-FX12 Digital Camera Problem
a possible issue with the film circuit on the CCD image sensor to the LCD. repairable but may cause you some bucks, but you can get this fixed.
Nov 09, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
My camera is panasonic lumix dmc-fx 50
hello psdubbs, maybe you should reset the function parameters, they could have been changed.
Jun 25, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Lumix pictures blurry
Oct 27, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-FX9 Digital Camera Logo
259 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
