My laptop is not able to sense my external USB gemini mini wired optical mouse. My laptop is with my friends one day, but once I started my laptop, the laptop is not respondeing to my mouse. Its red light under the mouse glows as normal. And also the touchpad is also working. I tried many things including I formatted my laptop too, but there is no solution. I have windows xp SP2 operating syatem. My mouse manufacturer is Gemini, model no is - M409. Please help. Your help is deeply appreciated. Thank you
  • Anonymous Feb 26, 2009
    please help
My Dynex optical wired mouse just stopped working. I tried plugging it into several different computers, and it would come on for a second, until I moved it and then the light would go out for a second. If and when the light came back on, the cursor and clicks no longer moved or did anything on screen.
I've had this mouse for several months, and it just randomly stopped working today, so I took it apart and figured out that the problem was originating from the usb cord. At the point where the little wires come out of their sheath and plug into the circuit board, the wire that bears the current was touching the ground wire, causing it to short out when I turned the cord (which explains why it would stop working earlier when I moved the mouse. Seems like the two wires should be insulated until the millimeter before they plug into the board, but they weren't. Too bad most people probably will just throw the mouse away or take it back without realizing what the problem is. I wonder if this is a common problem for others?
Posted on Jun 15, 2011
    Sergeant:
  • 207 Answers
Have you tried the Mouse with another computer?
If you did and it worked, my guess would be a driver issue.
If you did and it didn't work there may be a problem with the mouse.
If you haven't the please do so and let me know what your results are so I can try to help you further.
Thanks
Dave
Posted on Nov 06, 2008
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
Belkin wireless mouse won't connect on power up of PC
A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
1 Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
2 Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
3 Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
  • close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
Jul 17, 2017 | Belkin Mini Wireless Optical Mouse...
My compaq nc6120 boots ok but some time it just freezes and the mouse would not move until you wigil the pc from right side, what could be the problem plz?
If you are using an external usb mouse, then there must be a loose wire connection. Try to replace our mouse and see if it's working properly now. Have a nice day friend.
Aug 18, 2011 | HP Compaq nc6120 Notebook
I have hp mini 210 laptop. I connect usb dongle of optical mouse to laptop. It installed automatically & successfully. It showing in device manager (Human interface device) but still optical mouse is...
Welcome to FixYa!
Here's a quick checklist to resolve your wireless mouse connection.
Solution 1.
1. If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2. Make sure that the battery of the wireless mouse is placed correctly and is not drained.
3. After checking the first two steps, the optical lens on the underside of your wireless mouse should be flashing once in a while. If not, there is something wrong with the battery, the wireless mouse switch, or the wireless mouse itself is defective.
4. Connect the USB dongle in the USB port and let it install automatically.
Solution 2.
5. Connect the USB dongle in another USB port and let it install automatically.
Solution 3.
6. Restart the computer with the wireless mouse turned on and the USB dongle inserted in the computer.
Solution 4.
7. Download and install the drivers from here http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&dlc=en&softwareitem=ob-47909-1
I hope that this will help.
Thank you for using FixYa and keep me posted!
Jas247
Mar 15, 2011 | HP Wireless Optical Mouse
Mouse wont move on laptop
This issue might be with the drivers.
Try to find out the laptop driver CD and install.
Need to reboot the laptop once driver installed.
After restarting check it is working.
If not it might be with hardware issue.
It might cost you a bit more if it is hardware issue. For alternate you can use USB mouse(external), so it would cost about Max $10 for a USB optical mouse.
Nov 03, 2010 | Dell Computers & Internet
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Jul 30, 2009 | GE Optical Mini Wireless Mouse 98793
Wireless mini mouse
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 20, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Mouse inop. had a microsoft wired mouse installed prev.. could that be the problem?
Larry, delete the old mouse from device manager. and restart the computer. plug in your minimouse,dont let it automatically install, and run the drivers
keep me posted.
Nov 15, 2007 | Belkin F8E874 Mini Wireless Optical Mouse
Computers & Internet Logo
600 people viewed this question
David Payne
David Payne
