Question about Dell 922 All-In-One InkJet Printer
When I click "Print" paper feeds through the printer, but nothing prints
When I try to print, the computer and printer operate as they always have, but the page comes through blank. The message I get is "Right hand cartridge incorrect." The right hand cartridge is the color cartridge is the color cartridge and it is still at least half full. It is not just that it doesn't print in color, it doesn't print anything at all.
  • 2 more comments
  • jmlani7 Jul 29, 2008
    My 922 menu bar gives an error msg: right cartridge incorrect. It is the black and white. Both cartridges were refilled by Walgreens. The black and white right one was rechecked by them electronically for head problems and found none. They recycled for another refill just in case it didn't fill the last time. After installation again, I get the same error msg. Each time I print I get a blank page. The printer acts as if it is reading and printing but comes out blank.
  • brigitte93 Aug 17, 2008
    our printer is doing the same thing.....
  • Anonymous Sep 09, 2008
    havin the same problem too, tried 2 sets of inks... think the only solution is to go genuine maybe?
  • Anonymous Sep 11, 2008
    my computer is doing the same thing, I refilled the old cartridges myself and just bought some new ones from office depot-same thing nothing prints from either cartridge. HELP!
Hi all , had the same problem, searched for answer everywhere , found none.
Then I did this: you know the solvent that come in refill kit, that semitransparent liquid in the 4th bottle...
I used that to clean very well the cartridge head, the small contacts on the back , and the small contacts on the printer, where the cartridge is connected.
And when I put the refilled cartridge in it started to work, no "incorrect right cartridge" message.
I hope this helps
Posted on Oct 05, 2008
I'M HAVING THE SAME PROBLEM. LET ME KNOW IF YOU FIND A SOLUTION
Posted on Sep 06, 2007
    Problem Solver:
  • 7 Answers
Go to printers and faxes folder, right click the printer and go to 'printer preferences'. under preferences go to advanced tab and click on button "more options". uncheck the box that says "use color cartridge to print all black. Click Apply and then OK.
that should resolve the problem if your printer feeds paper through and prints nothing on it, yet it prints when you copy or scan something.
Posted on Feb 17, 2009
2 Suggested Answers
pineworks
  • 4293 Answers
SOURCE: States "Right Cartridge incorrect"
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
Its prints one page at a time and a pop up appears that says "press cancel button (manual feed mode)". I do this and nothing happens. Why will it not just print the entire document at one time? I...
You need to change the default tray. Thats the reason its printing one page at a time. You can change the default tray to draw paper from two ways, by using the controls on the printer itself or by changing the settings when you print a document.
To change it on the printer, go to menu on the printers keys and scroll the options until you find the print settings. Use the up and down arrows to scroll and press enter or OK when you find print settings. Continue to scroll until you see the default paper tray and change it from the manual feed choice to the default paper tray.
If changing from the print settings in the computer, when in a document that you want to print go to file at the top of the page and then print and click on preferences. Click the tabs at the top until you see the paper tray that is currently being used and click the arrow next to it to change it to another. Then click "ok" and close everything.
Dec 07, 2010 | Samsung ML 2010 Laser Printer
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
try to reload your catridge on the carrier or cartridge holder..
and clean your printer tab circuit and also the cartridge tab circuit and run maintenance page on it..
go to your printer panel and select maintenance ..browse clean printhead..and print maintenance page..to clean the cartridge..
May 18, 2009 | HP Office Equipment & Supplies
Paper feeding through printer but not printing
hi! if that printer doesn't print at all,since it was configured by your computer,try to check it's properties to test the function of your printer.doing this go to control panel click printer,then right click printer,click properties.on properties click test your printer,if this printer, print but nothing appear on paper,back to your properties and go to maintenance,on maitenance click clean printer,on try deep cleaning if still doesn't print bring your printer to cannon service center to check the printer head. regards and thank's
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Unable to print photos
Are u selecting photo paper in the type of paper?
try wiping the feed roller with an damp cloth.
Dec 15, 2008 | Office Equipment & Supplies
Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
Can't print onto thick card
Have you tried specifying the paper type and weight INSTEAD of the tray. Set the tray properties first, then print. If you leave it on auto tray it will use the tray that matches your paper type and weight.
Jan 09, 2007 | Konica Minolta bizhub C351 All-In-One...
Dell 922 All-In-One InkJet Printer Logo
1,367 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
