Question about Victory VegasLow 26 Men's Dual-Suspension Mountain Bike
Bicycle Rear Wheel Problem
Don’t know how to fix bicycle rear wheel problem, the wheel turning, but it is wobbling around.
Do I have to buy a new wheel or can I fix this? If this can be fixed, please tell me how.
Appreciate your help.
  • Anonymous Apr 16, 2009
    the wheel wobbles side to side when going down hills, it is not the axle because that is tight on both bolts it's the cones i been told
You may have buckled your wheel if its a spoked type ! If you have buy a spoke key and tighten the spokes opposite the buckle if the buckle goes over to the left stop wheel and tighten spoke that lie on the right of the rim fairly easy if your rim is not to badly damaged..... you will have to keep on tinkering to true the wheel also check your spoke are tight before starting as i have seen spokes just loosen for no reason.......hope this helps.
Posted on Nov 02, 2008
  • 19,396 Answers
Tighten the two pinion gear bolts that are holding the rear wheel, if the wheel is wobbling, then that is the problem.
If this does not fix the problem, you will probably better buy a new wheel, or replace the whole pinion gear and axis assembly, better to replace the wheel.
Posted on Oct 29, 2008
How does the gear assy. come off the rear wheel. i have to replace some spokes and the assy is in the way..
Posted on Jun 10, 2009
    Problem Solver:
  • 4 Answers
Sounds to me like the bearing cone nuts are loose. Your local bike shop should be able to sell you a cone spanner, which is a very thin spanner that help you to adjust the 'cones' which are held within the frame on the axle.
I could fix it for you for free if you come to Alice less car!
Why is the rear wheel moving side to side on ladies venture crystal oversize mtb bicycle?
Sounds like a bent rim or it's out od square in the frame.
To check the "Out of Square" measure the distance from the rear axle to a point on the frame on each side of the bike. To check the rim for trueness; take the wheel off the bike mount it on a holder (or just hold it out at arms length with both hands and have someone spin the wheel; if it spins straight, the problem is being out of square on the bike, if it wobbles it's a bent rim.
Jul 14, 2014 | 2000 Ford Focus
On my motorized gas bicycle the rear wheel wobbles what is causing that and how do I fix it?
Not sure about the Ford Focus issue?? If your motorized bicycle has wire spokes, they should be adjustable. Just tightening the spokes will pull the rim to that side. The opposite when loosening them etc.
If your wheels are of the mag type like a car, then maybe a bike shop can straighten out the wobble without more damage.
Jun 17, 2014 | 2000 Ford Focus
Why On my motorized bicycle the rear wheel wobbles what is causing that and how do I fix it?
probaly a wheel bearing wearing out. becones worse when it gets hot
Nishiki bravo bicycle will not engage gears when pedalling
has the cog seperated or snapped off the wheel as in can you freeturn the wheel and make the cog go around or does the wheel spin but the cog doesnt move,
if so your up for a new rear wheel/cog
Jan 28, 2013 | Cycling
I need to change the rear gear sprocket, but don't know what speed the mountain bike is. How can I tell what speed the bike is.
Count the cogs, duh. You're going to need some help even after you know if it's 6-, 7-, 8, 9- or 10-speed in the rear. Special tools and 'how-to' knowledge. Take it to a Bicycle Shop an experienced DIY cycling friend.
Sep 01, 2011 | Cycling
Where can I buy replacement spokes for an SRAM S30 sprint rear wheel?
You could Google that. "SRAM S30 sprint rear wheel spokes" or call a shop that sells SRAM wheels.
Aug 31, 2011 | Cycling
I bought a Huffy sea star 20 inch bicycle last year, the rear wheel keeps puncturing the inner tube, a spoke has come loose and the wheel wobbles. can't find a replacement wheel. Help!!!!!
Don't replace the wheel, get it fixed. The spoke can be tightened and the rim tensioned and trued. The rim strip probably needs to be looked at for exposing the spoke ends to the tube.
Mar 27, 2011 | Huffy Cycling
Where can i buy a rear wheel for this bicycle
Bike shop, eBay, Performance Bicycle catalog? Look for a 26-inch MTB wheel with a Shimano 7-speed cassette body on it. If that makes no sense, take it to a bike shop and get it right the first time. They'll also have the special tools to transfer your gears to the new wheel.
Wanna see what's involved?
Feb 06, 2011 | kawasaki KDX126 Dual Suspension Bicycle
Rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Jun 11, 2009 | Cycling
When i push on the pedals the backwheel doesnt go around
You my friend have a stripped free wheel.  The only solution is to get a new free wheel or just go out and get a new rear wheel all together.
Feb 14, 2009 | Dell Dimension BMX Cassette hub 48h...
Victory VegasLow 26 Men's Dual-Suspension Mountain Bike Logo
1,732 people viewed this question
Top Victory Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Victory Cycling Expert? Answer questions, earn points and help others
