Question about Ricoh Aficio CL3500N Laser Printer
Toners I have a Richo CL3500n and I have always purchased toner cassettes when I needed new color... I was wondering if I can purchase tonner in bottle from and refill the cassette... if so how do I refill?
  • Ricoh Master
  • 691 Answers
Sorry for long delay. Yes you should be able to buy toner to refill your empty carts. i always recommend using original stuff though. Saves any complications and possibility of wrong toner type getting used.
Posted on Nov 09, 2008
Richo sp 310 dn red light for tonner blinking. what is the solution?
Install a new toner. The toner light is your indicator that the toner is empty.
Jan 31, 2017 | The Office Equipment & Supplies
I have Samsung CLX 3175 laser printer. Am getting invalid toner message although parts are genuine
Well, eventually I worked it out: The "contacts" are four square fields to the left on on the backside of the cartridge. And it works instantly. (I read somewhere that it needs to be fully transparent tape. The 'blurry' tape leads electricity and doesn't work.)
Mar 13, 2012 | Samsung CLX-3175FW Multifunction Laser...
Samsung CLP 315 invalid toner message
the best thing to do is buy the original toner. how ever if u really can't then try changing the blue colored one
Jul 29, 2017 | Samsung CLP-315 Laser Printer
Tonner is exhousted, what is this solution
You need to purchase a new toner cartridge for your printer or purchased a re-charged toner cartridge.
A re-charged toner cartridge is cheaper than a new toner cartridge.
Nov 24, 2010 | Computers & Internet
My printer does not sence the one of tonner catridges of the colors , is it the sensor
Are you using remanufactured toners or HP OEM? If your using Remanufactured, I'm pretty sure its the chip on the toners. Try your old one and see if it will recognize that.
Jul 30, 2010 | HP Color LaserJet 2600n Printer
How to make copies darker? I tried adjusting the machine manually . Color balance is way off too. Help! Gale T
1) First check to make sure your toner levels in the cartridges are not mostly used up. This can cause faint printing also.
2) Make sure you don't have a "Toner Save" feature selected in the printer's onboard setup menu.
3) As for the color balance, you should be able to select a "calibration" of the toners. That should automatically happen when you power the printer on, but sometimes you may have to do it again.
4) Finally, if you are using cheap, compatible toners purchased online, or refilled toners that might be the source of your problem as well.
Apr 26, 2010 | Lexmark X502N All-In-One Laser Printer
Konica Laser says no toners installed. How do you
Take the tonner catridge and shake it left to right and reinsert then it will be ok
Dec 20, 2009 | Epson Aculaser C1100 Printer
Konica minolta 2400w toners problem
My Konica 2430DL does this every time I start the printer, I am quite sure it is supposed to do this as I it rotating the toner and calibrating itself. On one occasion I recently had the status monitor say to install cartridge... I removed it, shook it, reinstalled it with the same results. I just purchased a new Konica brand toner, replacing the old one and 'voila' sucess! It still does the little dance (rotation) every time, but it always has, but after installing the new toner the message went away. If you reinstalled the toners, this may be your problem - you need all new toners; spendy but it should solve your problem, otherwise; if you've already done this, I don't have an answer. Good Luck!
Dec 28, 2007 | Konica Minolta magicolor 2430 DL Laser...
Faint printing
I have installed brand new toners that were bad. Fortunatly it was at work so I didnt have to personally purchase a second one to find out. But it does happen, espically with reconditioned toners or off brand toners
Jul 03, 2007 | Samsung ML 2010 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
